Lighting Upgrade
19 replies to this topic
  • 1bar2barfubar
Posted 14 October 2005 - 01:28 AM
Well, my headlamp upgrade is nearly complete. Some quick history -- I had an HID kit installed in the stock reflector, but was never really happy with the lighting pattern. Put on some small driving lights but they drained the battery. So I threw down 200 bucks on ebay for a headlamp from an 05 Nissan Maxima and ripped out the projector, ballast, etc.
Picked up a sheet of aluminum and bent a crude bracket that attaches to the stock mounting brackets, and glued in part of the projector mounting ring with some JB Weld. The Maxima light came with a small projector fog light that I have yet to install, so it looks a bit ghetto.
I ran a seperate wire from the battery to power the ballast, but in retrospect I could have used the stock wiring and a diode to insure that the ballast stays powered when the high beam is switched on.
The lighting output is amazing -- it lights the road in an even 180 degree swath, and the low beam range is roughly twice that of stock. The projector is bi-xenon, so there is a solenoid which moves a shield inside to throw the light further. I'll get a picture of the beam at night as soon as it stops raining.
http://img450.images...imgp07996vt.jpg
For more info on HID projectors, check out HID Planet Forums
Also, I am selling my stock headlight and the HID kit I had in there, PM me if you want it.
  • FLEALAMI
Posted 14 October 2005 - 04:49 AM
You, sir, are a bright man. :)
Flea
  • ric6312
Posted 14 October 2005 - 08:48 AM
i cant like the way you took a fine looking bike and did that to it.hope you can inprove the overall look because it looks bad in my opinion.
  • FLEALAMI
Posted 14 October 2005 - 09:30 AM
Yes, can we assume that you are not finished with it?
Flea
  • 1bar2barfubar
Posted 14 October 2005 - 11:10 AM
Yeah, it is a bit ghetto, sorta Mad Max style. I am either going to make a whole new front faring out of aluminum or fiberglass up the sides of what I have to match up with the stock faring. Work in progress.
  • pobo
Posted 14 October 2005 - 09:27 PM
Can't knock being able to see at night. I hate it when I out run my field of vision, like blasting through fog hoping the road is stright AND clear!
  • DT
Posted 17 October 2005 - 05:31 PM
http://www.ryleesmit...t/DT%20Bike.JPG
This is my headlight upgrade on my 1998 DR650 It is from a Buell City X. The lights are brighter than my Chevy truck. And by removing the stock glass light and steel brackets it was a weight savings of about 6.5 lbs. :applause:
The link is fixed sorry :bonk:
  • milk
Posted 17 October 2005 - 06:44 PM
DT- your link is telling me i need to sign in to see your pics.
lately i've been thinking i need to adjust my headlight or something. it's been dark in the mornings on my way to work now for a while and even with my high beams on a clear morning my lights seem to fall short.
  • FLEALAMI
Posted 18 October 2005 - 08:57 AM
I registered for the web site, but then what? Where am I supposed to look in?
Flea
  • brianwheelies
Posted 18 October 2005 - 10:09 AM
Just look up the member DRZOOMN and go to his garage. I'm pretty sure he's the one who pioneered this with his drz400.
http://www.thumperta...vehicle&vid=203
  • DT
Posted 18 October 2005 - 02:27 PM
Yes the idea was Andrews but this is the first on a DR650 that I know of. :D
  • brianwheelies
Posted 18 October 2005 - 03:10 PM
Any pics? After the thread over on the junkie, i want to do it as well. :thumbsup:
  • DT
Posted 18 October 2005 - 03:34 PM
Here you gohttp://www.ryleesmit...t/DT%20Bike.JPG
  • brianwheelies
Posted 18 October 2005 - 03:54 PM
Very cool! Looks better on the 650 than the 400 :applause:.
Now, how did you end up mounting? Seems pretty easy from what i read over on the junkie.
  • irondude
Posted 18 October 2005 - 04:00 PM
bi-xenon... :eek:
  • Wybs
Posted 19 October 2005 - 04:17 AM
Where did the lights come from? I have been checking into this as well. I think replacing the stock is the best option due to lack of watts from the generator. Speaking of which do you know how many watts they are?
Thanks
  • kbuckey
Posted 19 October 2005 - 04:57 AM
DT - Now that is the first light upgrade that really gets my attention. Looks good and sounds like it really lights things up. How much trouble was that?
  • brianwheelies
Posted 19 October 2005 - 10:06 AM
I'm considering getting rid of the stock headlight and converting over to dual trail tech hid's. After reading about their output, wattage draw, ease of installation, i think it's the way to go. Will have to do a custom fairing up front though.
  • DR_Motard
Posted 20 October 2005 - 12:10 PM
Here is my lighting upgrade.
-Drew
  • brianwheelies
Posted 20 October 2005 - 02:34 PM
Crikey, those are huge. Getting ready for the Baja 1000, are we?
