Problems Starting After Wash
7 replies to this topic
  • WR426Frider
Posted October 12, 2005 - 02:28 PM
I have a 2002 WR426F, yesterday i got back from riding and decided to wash it. I after i washed it, it would not start. It is getting spark from the coil, but i do not have a tool that can get the spark plug out. Also I did not have the exhaust pluged or the air box pluged, i just tryed not to get any water in ether, but when i kick it it sounds like there is water in the exhaust, so i took it off and drained it, only a little was in it. Could water have got into the carb? Any help would be much appreciated.
  • biznet1
Posted October 12, 2005 - 03:22 PM
You can use a 3/8 drive universal with a small extension and ratchet to get the spark plug out. You can get a universal from walmart for about 3 bucks.
  • Troutman
Posted October 12, 2005 - 03:37 PM
Remove the air filter which will most likely have water in it, let bike and filter dry by sitting 1 day and then re-install filter. Biznet is right you need a universal to get the plug out - replace plug if needed. It most likely needs to dry out give it some time especially if you sucked some water into the carb.
Good Luck.
  • WR426Frider
Posted October 12, 2005 - 04:03 PM
The filter was wet, I well let it sit and well get a universal and check the plug.
  • sirthumpalot
Posted October 12, 2005 - 04:42 PM
Clean or replace the plug and I'll bet it starts right up. These are pretty water tight (as long as you don't soak the filter or exhaust).
  • Ga426owner
Posted October 12, 2005 - 05:40 PM
It is too easy to get the air filter wet - it is and that is why it won't start
  • WR426Frider
Posted October 12, 2005 - 05:54 PM
Well, i let the filter dry and then i tried to start it. When i kick it, it makes a gragling nosie. i well check the plug tomorrow
  • WR426Frider
Posted October 13, 2005 - 04:52 PM
I took the plug out and cleaned it, and let the bike sit a two days. Today it started on the second kick thanks for the help!
  • Hot  50 replies
  • 0 replies
  • 10 replies
