Checking compression on a 650r.
5 replies to this topic
  • bosshog
Posted October 09, 2005 - 07:04 PM
I was thinking of checking the compression of my BRP. No problems but wanted to see how it's doing. So how do I do this on the 650? Do I have to take off the mag. side cover and turn it over that way as to not have the auto decompression foul up the readings? What readings should a 650r in it's prime have? What #'s are acceptable and when is it time to worry? I may do a leak down test as well after. It runs great, I check and adjust the valves regularly and change the oil almost as often as I fill the gas tank. I just want to get an indication of it's general health.
Thanks guys
  • wr450fyamaha
Posted October 10, 2005 - 09:11 AM
do u have a compression testor?
  • TimBrp
Posted October 10, 2005 - 10:44 AM
If you've got the stock manual all the specs should be in there. If I was at work I'd throw a link up for the online one...anyone got that link handy?
  • bosshog
Posted October 10, 2005 - 05:28 PM
I downloaded the manual now thanks. And yes I the tool to check compression.
  • knuklehead
Posted October 10, 2005 - 05:58 PM
A better gauge of how it's doing would be a leak down test :banghead:
  • bosshog
Posted October 10, 2005 - 06:05 PM
Ya I'm going to do that as well. Weather is starting to suck and I just can't leave the bike alone. :banghead: When it gets to bad to ride anymore I'm afraid I'll just have to spend money on aftermarket stuff to keep sane.
