05 forks on 03 450?
10 replies to this topic
  • walent215
Posted October 09, 2005 - 02:09 PM
just curious if anyone knows if it can be done with different clamps and stem.
  • ripntear
Posted October 09, 2005 - 02:28 PM
I think so.
grayracer did one using '04 forks on his '03 450 and I'm pretty sure he said the same could be done using '05 forks.
  • walent215
Posted October 09, 2005 - 03:23 PM
I think so.
ya i remenber reading about that but wasnt sure since the 05 has the new forks.
Posted October 09, 2005 - 06:49 PM
The information I have is that the '04 and '05 YZF take the same clamp from aftermarket suppliers, so....it should work if that's true.
I'm not yet totally sure what the story with the stem is, but at the very least, the '03 stem does definitely fit the '04 clamp. That was how I did mine. What I'm not sure of is that the stem that came with my '04's was too short by around 1/2", but I don't know if that's because it was for a 250F (which is where the forks came from), or because all the '04's are different. The '04 250F and 450 have two different bottom clamps, according to the parts book.
The fork tubes on the '04 measure 59.2mm at the bottom clamp, and 55.8mm at the top.
  • walent215
Posted October 10, 2005 - 05:16 AM
thanks for the info. :banghead:
  • ncmountainman
Posted October 10, 2005 - 02:12 PM
the stem is the same(450's) from 03-05 and the 46mm clamps are interchangeable with the 48's. i've got 03 forks on my 05 :banghead: and before my emig offsets i had 04 WR stem and clamps on it(46mm). the lower clamps are only available from yamaha with the stem, so i'd venture a guess that the 250's clamp is possibly different in stem length :banghead:
  • walent215
Posted October 10, 2005 - 02:38 PM
do your clamps come with the stem and are they offset?
  • biggiesyup42
Posted October 10, 2005 - 02:54 PM
I may have 05 Yamaha YZ450F forks available in a week, I'm debating parting out my bike and those will need to go. I can sell the clamps to go with the forks so you will have no problem mounting them to an 2003. What are you willing to pay?
  • walent215
Posted October 10, 2005 - 02:55 PM
are they stock?what spring rate?how much time on them?
Posted October 10, 2005 - 03:07 PM
The more I look, the more that appears to be the case. Applied lists a stem for the 250F as a separate part, and refers to it as a "short tube" :banghead:
  • ncmountainman
Posted October 12, 2005 - 04:21 PM
the hurricanes (48mm) are uppers onlybrand new. i've a set of used hurricanes (46mm) withan applied bottom clamp w/stem,can cut ya a deal on'em either way :banghead: niether are offset
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • Hot  47 replies
  • 0 replies
