06 450 frame, battle tested?
5 replies to this topic
  • HGaither1
Posted October 06, 2005 - 03:59 PM
I am assuming that the new aluminum frame has been battle tested, right? The main backbone just looks a little thin compared to the crf. Also what is the deal on the new oil tank within the engine? Does anyone know how much oil it actually holds?
  • Satch0922
Posted October 06, 2005 - 06:15 PM
you can bet the frame is battle tested. Keep in mind the YZ250 2-smoke frame is A LOT thinner than the CR250R frame....and it works flawlessly.
  • Matt96xr6
Posted October 06, 2005 - 06:40 PM
Well Yamaha has been playing with aluminum frames since the 80s.
So quick answer is yes.
  • Jetsprint2
Posted October 07, 2005 - 07:34 AM
Hard to tell about the oil question, since the bike is not out yet. However the engine is still close in design to the 03-05 so I would imagine that the oil capacity is the same as well- it is just not carried in the frame- the new design helps lower the center of gravity and is less likely to leak due to frame cracks wich are very rare but has happened. It is a good design and I can't wait to see an 06 in person. I just might have to get one. :banghead:
Posted October 07, 2005 - 08:44 AM
Adding additional oil capacity through the addition of an auxiliary tank would also be a fairly simple matter (if you can tap into the return circuit without too much trouble), if you though it was necessary. Hopefully, it will be at least one quart.
  • Matt96xr6
Posted October 07, 2005 - 04:36 PM
The engine really is different from the 03-05s. Yes it still has the 5 valves, but the angle of the engine is different. It is an ALL new motor basically. The bottom front of the motor has a cavity to store the oil. 1qt is what it takes now. There are a lot of slight and small differences.
  • 0 replies
  • On Yesterday, 06:20 PM
  • Hot  36 replies
  • Hot  113 replies
