WER damper installation Photos
1 reply to this topic
  • AUS_WR450
Posted October 06, 2005 - 05:01 AM
G'day All,
If anyone has a WER steering damper installed on their WR450, please could you send me some photos of the installation. In particular, I am interested in seeing how the actuator arm passes through the headlight shroud, and also how the U shaped bracket, mounts onto the steering head.
My email is spammer@optusnet.com.au (yes, it is a fair dinkum email address)
regards,
Nigel
Sydney
  • ncmountainman
Posted October 06, 2005 - 07:24 AM
i would not reccomend that you use that u-shaped bracket,you must drill through the oil reservoir part of the frame to use it. i made up a bracket from 3/4" angle iron and tig welded it to the frame(be sure to disconnect the CDI) as far as the headlight shroud you must cut some of it away. its a good unit and worth the extra effort, i like it because its action is hardly noticeable,but very much there at speed. i'd describe it as a "damper for people who don't like dampers" :banghead:
