Fork setup help
1 reply to this topic
  • gmiles
Posted October 05, 2005 - 12:39 PM
Gents I have a year 2000 yz426. When I first got the bike it handled like a dream. When I started getting faster I found that I was bottoming out the forks over most jumps. I had the fork oil changed. The height was raised to 100mm. What a difference. They were a lot firmer throughout the whole range. However, that was a year ago. I have since got even quicker and the forks have started to bottom again.
Apart from the oil height change the forks are setup as stock. I see I have two choices.
1. Keep the oil at 100mm but change the weight of oil. Would 7.5wt make much of a difference or should I go to 10wt.
2. This is a european spec bike so the fork has 4.5N/mm springs. Should I go to 4.6 or 4.7.
I weigh around 210 pounds.
Any advice would be great.
Thanks
  • Jetsprint2
Posted October 05, 2005 - 12:59 PM
Thanks
Definately up the springs for your weight. The forks were not that good on the 426 you may want to upgrade them if you keep getting faster maybe even a newer bike.
  • Hot  113 replies
  • 10 replies
  • 0 replies
