Tell me what you think of this starter, replace?
8 replies to this topic
  • duke2au
Posted October 05, 2005 - 12:28 AM
Thanks for looking, I tore down the starter tonight and realise that looking at these brushes that they will need replacing, I am wondering about the starter though??
There was alot of carbon that fell out of the starter when I cracked and it seemed pretty dry. I will be replaciing the brushes tomorow, but from the looks of the rotor do yo uthink it needs replacing?
have a look at the pics.
http://bensville.cus....au/WR/starter/
thanks
duke2au
  • fitzy
Posted October 05, 2005 - 01:35 AM
Give it a clean in carby/brake cleaner or similar, put in the brushes and try it. Going through the same thing at the moment
  • 450high
Posted October 05, 2005 - 02:13 AM
Your brush end bearing ( bush ) looks like it needs replacing also.remove the brushes by unsoldering then take the brush carrier out .Then screw a bolt or thread tap into bearing against the end plate to push it out.I could not get the bearing from yamaha so i went to a bearing shop and bought the closest size and had a mate run it down to fit in a lathe.My bike appeared to have a flat battery but it was a bad bearing letting the starter shaft go side ways.Took a while to find the problem.
  • Indy_WR450
Posted October 05, 2005 - 03:12 AM
As long as the epoxy is holding the motor windings together clean everything up and replace the brushes. :banghead:
  • simon@vic
Posted October 05, 2005 - 07:15 AM
mine looked good, and tested ok. but gave up the ghost...............
  • Blaster21996
Posted October 05, 2005 - 08:57 AM
thanks
duke2au
Toss that mess and put a new one in...... but, hey, that's just me! My 05 started going south after 3 months of use. I tossed that P.O.S. and put a nice new one on. Now she's happy! :banghead: I think it was assembled wrong from the factory, because the 2 long screws were misaligned, thus, wearing the bearing and brushes prematurely!
  • duke2au
Posted October 05, 2005 - 01:24 PM
When you turn the motor from that shaft, is it supposed to spin freely, or does it have a kind of "rolling click" to it?
I am thinking back to my electric track mini race car days, and from what I remember it was sor of a rachet type feel when you rolled the back tires.
I just know how to take em apart, I'll be buggered if I know how they work...
thanks
Duke2au
  • jbrooks26
Posted October 05, 2005 - 03:44 PM
Don't waste money buying a new one unless yours is bad. I assume it worked before you tore it apart. Just clean it up good, and check for damage. Wear is normal in a motor, and all of the carbon you are talking about is most likely from the wearing of the brushes. Replace the brushes, and if the commutator(the part the brushes ride against) has any grooves in it, you can chuck it up in a drill press or better yet a lathe and use some emery cloth to smooth it out. It will be good as new. Check the bushings and bearings out and replace them if necessary, but I would not expect to need that just yet. Hope this helps.
Josh
  • duke2au
Posted October 05, 2005 - 07:53 PM
thanks for the advice, Apparently the bike has only about 1000 Klms on it. I would suspect the 18 year old that had it before me never kicked it.. He dropped it a few times though. :banghead:
