Replacing Throttle tube, What kinda grease?
14 replies to this topic
  • ridered50230
Posted October 04, 2005 - 03:37 PM
Alls i got is Multi purpose Lithium grease and I am replacing a throttle tube. Can I use this between the bar/tube or what?
  • ttr125lerider
Posted October 04, 2005 - 03:52 PM
hmm.. i didn't use anything between the bar and tube i dont think when i replaced mine, the tube doesn't really come in contact with the bar
  • ridered50230
Posted October 04, 2005 - 04:13 PM
well... i put it on and it rubbed so idk?
  • CV4
Posted October 04, 2005 - 04:46 PM
I wouldn't recommend putting any kind of lube between the throttle tube and bars. It will only attract dirt and dust and most likely cause problems in the future.
  • Cozza
Posted October 04, 2005 - 04:47 PM
When I put mine back on. I had waterproof bicycle bearing grease, so I put some in between. The only down side is I see it collecting more grime in there. so check it often.
  • J_Daniels
Posted October 04, 2005 - 06:03 PM
Yup, grease will turn to sludge before long. Best to leave it dry as the nylon- type plastic of the throttle tube is slippery anyway.
  • Trailryder42
Posted October 04, 2005 - 06:49 PM
Like the others have said, install it dry. Don't use anything between the tube and bar.
  • 4STOKED
Posted October 05, 2005 - 06:41 AM
try using a silicone lubricant spray. lite and easy.
  • Robbo66
Posted October 05, 2005 - 06:52 AM
I use graphite powder. Works a treat.
  • ONLY4STROKES
Posted October 05, 2005 - 07:05 AM
Ditto. Just use some WD40 and you'll be good to go.
  • Powderhound
Posted October 05, 2005 - 08:40 AM
I would never use any kind of lube unless you want to be taking it apart all the time to clean it. Graphite powder would work well I bet. I can't immagine wanting a more sensitive throttle though.
  • learning2fly
Posted October 05, 2005 - 08:43 AM
I went with an aluminum throttle tube after breaking three plastic throttle tubes, and didn't like the metal on metal drag, so I use a little graphite powder when I replace my grips or have to clean it out after a bath in the mud. Anything liquid will attract dirt. :banghead:
  • xrMike
Posted October 05, 2005 - 10:01 AM
Yeah, graphite is about the only thing you'd want to use between throttle tube and bar, if anything at all.
  • ridered50230
Posted October 05, 2005 - 02:28 PM
well when he cracked it he bent up and chipped a bit of his bars so it created the friction, ill sand down the "debris" and it should be clean.
thanks
  • Kx250FRiDeR651
Posted October 05, 2005 - 02:36 PM
i know some people who work for transworld and answer/protaper so i get to go in the factory semis alot if im hanging out with them...when i was in the yamaha semi he was working on the bike putting a new throttle on...he used a very bright red thin grease, looked like it was a jelly type..not quite sure, but he did use grease befor putting the throttle on...ive seen this done many times by top mechanics
Beta VS KTM handling by abj1
Dirt Bike   Make / Model Specific   Beta
  • Hot  38 replies
Squish or #8 slide? by yz dude
  • Hot  27 replies
2005 YZ250F Throttle Position Sensor, Please Help me? by Yamaha_2005_YZ250F
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • 7 replies
Rmz 250 enduro conversion by SD513
Dirt Bike   Make / Model Specific   Suzuki   RM-Z 250
  • 3 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
