HELP! Played with clutch cable, now I can't get into gear without stalling...
5 replies to this topic
  • 94XR650LaJolla
Posted October 04, 2005 - 01:17 PM
So I just wanted the clutch lever to engage a little earlier, so I adjusted it at the lever and down by where the cable meets the engine. Now, I can't get the bike into 1st or 2nd without stalling! I fire up the bike in neutral, but when I shift it stalls.
I've been playing with the two bolts where the cable meets the engine and have tried with both it tight and loose, neither will shift without stalling.
Once again, my bike is not working....
Thanks guys!
  • 94XR650LaJolla
Posted October 04, 2005 - 01:37 PM
Go figure, now it works. I guess the bike just needed to be rolled a little more.
  • bay rider 16
Posted July 24, 2009 - 12:14 PM
I am having that exact same problem with my crf250. What did you do to make it work?
  • XR650L_Dave
Posted July 24, 2009 - 12:26 PM
Try turning the clutch lever adjuster on the handlebars out so more of the adjuster shows.
Dave
  • Denn10
Posted July 24, 2009 - 12:30 PM
YES that takes some of the play out and lever wont hit grips and will move the clutch and it should work better
  • HeadTrauma
Posted July 25, 2009 - 08:52 AM
Make sure there is a small amount of freeplay in the lever on the engine or it's possible for the clutch to slip and ultimately burn up.
