Top Speed for XR600R
25 replies to this topic
  • Dan Turner
Posted October 04, 2005 - 07:51 AM
What's the average top speed for an XR600R, with stock gearing?
  • TimBrp
Posted October 04, 2005 - 08:31 AM
I'd say 85-90mph.
  • Dan Turner
Posted October 04, 2005 - 08:56 AM
That's about what I was thinking, but it's hard to tell by the wind-o-meter.
Thanks,
Dan
  • Mantrasonica
Posted October 04, 2005 - 09:19 AM
My bike went something like 93 or 95 (I can't remember which) last Summer on el Mirage and its an 87!. The engine was screaming for mercy at that speed. Made several passes and used an entire quart of oil that day.
  • Dan Turner
Posted October 04, 2005 - 11:19 AM
Mine's an 87 too!
  • Mantrasonica
Posted October 04, 2005 - 12:43 PM
Mine's an 87 too!
Flog it!
  • wr450fyamaha
Posted October 04, 2005 - 01:11 PM
you guys and your 87's hehe. i would say 85 depending on mods.....but that would be pure hell to your engine.
  • Mantrasonica
Posted October 04, 2005 - 01:46 PM
Only mods are a re-jet, air filter and trapp.
Definitely hell on the 'ol mill. Still noticeable pick-up at 85 though.
Bring your GPS...we'll go for a ride!
  • SSpeeDEMONSS
Posted October 04, 2005 - 06:00 PM
600R's only do 90-95? my 426 does 85 with stock gearing and still pulling hard. thats on hwy 78 at Ocotillo. are 650R's faster?
oh, and im saying that they only do 90-95 with stock gearing, not that that is all that they are capable of. i just thought that a 600R would have a higher stock top speed.
  • don87xr600
Posted October 04, 2005 - 06:23 PM
stock gearing and 8 other mods.
  • moto_x2005
Posted October 04, 2005 - 08:46 PM
1988, id say 70-80, not with motor screaming
  • smashinz2002
Posted October 04, 2005 - 09:10 PM
Sounds about right. 600R does around 85-90 stock, 400R does about 75, 650R will do 100 with the usual uncorking/jetting mods and stock gearing. YZ426 will do 96 with stock gearing and no mods. KX500 will do about 88 in stock condition. All measured with gps.
They get to those speeds REALLY quick!
  • LotsOfBikes
Posted October 04, 2005 - 11:23 PM
Rear tire speeds..
107.91mph at 7500rpm
120-100/18 rear tire with knobs
Add one tooth to the front sprocket:
115.62mph at 7500rpm
Vegas-Reno XR600R's are clocked at this speed, with regularity.
  • XRsteve
Posted October 05, 2005 - 07:56 AM
I have an 1999 XR650L with 14-48 gearing, the same as the stock XR600R. It easily goes 80 and I figure it will go a little faster. It should be the about the same top speed as a 600R, mine weighs more but has 50 more cc's.
  • Dan Turner
Posted October 05, 2005 - 09:01 AM
Mine's got similar mods...jets are both 128's (I have no idea what stock jets are) drilled air box, FMF power bomb pipe, powercore 4 silencer, K&N. What jets are you running? I was running down a powerline road in the High Desert, CA, full throttle, 5th gear for about 5 miles. I was just wondering how fast I was going.
Dan
  • Dan Turner
Posted October 05, 2005 - 09:06 AM
Mantrasonica, what rear tire are you running? I'm running a Maxxis C6001 130/90x17. It grabs good but is wearing out quick. Knobbies are getting pretty rounded after 3 rides. I wouldn't mind having a bigger tire, but there's not many options for the 17 inch rim.
Dan
  • Mantrasonica
Posted October 05, 2005 - 09:47 AM
Currently have the bridgstone M22 (510) on the rear and a Dunlop 739 up front.
The M22 is wearing really well, but is squirly as hell in the sand. Believe it or not, I thought the Cheng Shin (530) I had on the rear was a better tire in sand.
No complaints with the D739
  • Mantrasonica
Posted October 05, 2005 - 09:56 AM
Dan
I'm running a 128 main in the primary and a 130 in the secondary. #42 slow jet (tried a #45 but it was too much, maybe this Winter I'll try it again).
My bike runs really strong in the high desert. el Mirage is where I dialed in the jetting. Runs real well at that altitude. I found that too many holes in the airbox killed the top-end performance, as did too many discs in the 'ol trapp. Two discs make a huge difference. Currently running eight with a stock airbox. Thought about trying 6 or 7 to see what happens. No real need though.
Now if my kick leg would hold out I'd be in business. The bike is a tough kick when I get tired.
Tim
  • Dan Turner
Posted October 05, 2005 - 10:06 AM
Tim
I hear ya on the kicking...I have no idea what slow jet is in mine. What exactly does the slow jet do? I too was running a 130 in the secondary carb, but it was popping (flames out the back, past the spark arrestor) so I decided it was too rich. I put the 128 back in, drilled a few more holes in the cover, and it seemed a lot better.
I have an extra set of carbs that I sent to XRs Onlys yesterday to have rebuilt. I can't dial out my intermittent bogging problem, so hopefully they'll do a good job.
Where in Cali do you live? I'm in Yucaipa.
  • Mantrasonica
Posted October 05, 2005 - 10:13 AM
I'm in Temple City.
I had an intermittent bog when I first got the bike. It was the float needles.
  • Hot  186 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  29 replies
