Oil Cooler Connection
3 replies to this topic
  • TREADMARKS
Posted October 04, 2005 - 03:07 AM
Where would one tap into the oil line to install an oil cooler on an 01 XR650L ? :banghead:
  • roadcam
Posted October 04, 2005 - 06:14 AM
the easiest place I have seen, is where the oil lines enter the frame
  • TREADMARKS
Posted October 04, 2005 - 06:56 AM
You mean cut the metal line to route it from the engine to the cooler, then from the cooler back to the metal line which goes to the frame reservoir?
  • roadcam
Posted October 04, 2005 - 07:20 AM
I believe it would be much easier to have the lines made up by a hydraulic-fitting shop, and just screw your fittings into the frame, and to the cooler, just like the factory would do it ... I've found hydraulic supply shops in most good-sized cities that will make up lines for you quite inexpensively ... the shops I've used (CIR- California Industrial Rubber, .. a chain out here in CA) .. have all the necessary metric fittings, etc ... even will make up stainless steel wrapped hoses, etc... Tip: if using a shop like that to make up brake hoses, they will balk because of liability ... tell them with a wink that the hoses are for hydraulic clutches, etc... :banghead:
  • 9 replies
  • 17 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
