Blowing fuses
3 replies to this topic
  • Flaminchiten1967
Posted October 02, 2005 - 05:44 PM
I was riding today and about 15 minutes into the ride I blew a fuse, no biggie put in a new one and not but 2 minutes later it blew also, the second blew right after using the E-start.
Anyone else have this problem? Is a wire grounding out somewhere maybe? btw it was the fuse by the positive side of the battery.
Thanks in advance :banghead:
  • Indy_WR450
Posted October 02, 2005 - 07:10 PM
Starter motor may have some broken wires or internal connections causing excessive load on starting and blowing the fuse. Try kick starting it and running it for a while and see if it blows. Check for any loose wire connections to the motor and if it does not blow fuses using the kick starter then you need to rebuild the starter motor or replace it for about $200.00 :banghead:
  • Flaminchiten1967
Posted October 02, 2005 - 07:58 PM
Thanks, I'll give that a try. I think the bike is stillunder warranty, is this something that would be covered?
  • Indy_WR450
Posted October 03, 2005 - 06:39 AM
Take it in to the dealer quick! 30 day warranty will cover the labor! :banghead:
