UH OH... should i worry!
13 replies to this topic
  • drive805
Posted September 30, 2005 - 09:32 PM
01 WR 426 .....changing oil, pulled out filter and there are metal chips in the filter should i worry?
I am the second owner and the first took meticulious care of it as i have so far but now i dont' know if i should trust it for riding is this normal?
anyone please...thanks in advance!
  • tp3dxf
Posted September 30, 2005 - 09:42 PM
Not unless they are big chips. It's common to get small particles of metallic looking stuff caught in the filter. My bike has been doing it for years. Zero problems.
  • Chris_from_Oz
Posted September 30, 2005 - 11:52 PM
Same here. When I STOP finding small particles in the filter, that's when i'll start panicking. :banghead: It's common for these bikes.
  • Birdie426
Posted October 01, 2005 - 08:19 AM
It's because the engine shares it's oil with the trans. The metal shavings are from gear teath, clutch basket/hub, etc, and perfectly normal.
  • drive805
Posted October 01, 2005 - 08:53 AM
WHEW thanks i've only had it a short time and wanted to make sure that something wasn't coming apart..
  • Bamster
Posted October 01, 2005 - 09:05 AM
Buy a Moose magnetic drain plug.
:banghead:
  • SJMC_DON
Posted October 01, 2005 - 02:02 PM
How often are you changing filters?
  • Rooster426
Posted October 01, 2005 - 07:21 PM
Yup, me too. At first I freaked out, I was getting flecks too (about the size of pepper). But no biggie, each time I change the oil, the filter has flecks in it, not alot so I don't get too worried. Realize this bike revs like a banshee out of hell, it's a wonder I don't get chunks of metal pouring out with each oil change.
  • Rooster426
Posted October 01, 2005 - 07:23 PM
I have the metal screen filter, I read you can just rinse it out and pop it back in. This is what I have been doing. Anyone else?
  • SJMC_DON
Posted October 01, 2005 - 07:57 PM
Yep, me too but even with the cloth filter I only replaced it about every 12th ride or fourth oil change.
Your all good :banghead: Just keep changing that oil and you'll have little or no problems
  • katoom525sx
Posted October 01, 2005 - 09:32 PM
I would also add that thoes metal chipps are from your clutch plates.
  • xr_man
Posted October 02, 2005 - 09:55 AM
yer , my 426 looks like you have been panning for gold when I was washing out the filter.......and so did my last one, and my buddys one !!
  • drive805
Posted October 02, 2005 - 05:33 PM
i have never changed the filter just washed it out, i have only had the bike about 6 months and have done 2 oil changes i was told to check and clean the filter about every third oil change i wanted to see what it looked like so i did it this time!
also i am using synthetic oil that is all the previous owner used and he said that i should stick with it!
  • JRAMBO
Posted October 02, 2005 - 06:47 PM
I usually wash it out three or four times then maybe if I have extra cash when changing time buy one then if not rinse it out or blow it out with air good to go.
