essentials for tool kit?
34 replies to this topic
  • xlr8
Posted August 04, 2002 - 11:35 AM
:D A couple of beers is standard equipment on some of our rides! Also bring the "Mini Leatherman", but we re-use the roaches! :D :D :)
  • fastmonstr
Posted October 05, 2002 - 05:20 AM
I am packing a tool kit for a long desert ride.(100+ miles a day for three days.)I need to be prepared to fix a flat. I have a spare tube for the front(it can be used in the rear for an emergency).
My problem is, the 27mm wrench for the rear axle is 14" long and will not fit in my fanny pack or fender bag. I was thinking about cutting it down, but I'm concerned about leverage.
Any ideas??
  • thebray
Posted October 05, 2002 - 06:57 AM
Many times it's the smallest of parts that break but you cant ride without it.Cable ends , exhaust springs , assorted bolts , master link , washers , cotter pins .
I broke a shift lever once so when I got home I drilled a hole and put a bolt in it then threw it in the pack as a spare.
The stuff that gets used the most is safety wire , zip ties , and duct tape of course.
  • desertfoxx
Posted October 05, 2002 - 08:47 AM
Up front in moose fender bag: 2 tire irons, 1 21 inch tube, small mtn. bike tire pump, 20' homemade towstrap. In back in moose folder pack: Copy of license, registration,insurance card and at least 20$, also 1 each 8mm,10mm,12mm snapon combo wrenches, 1 small modified 10" crecent wrench to fit both front and rear wheel nuts and other uses I also wrap about 5 feet of duct tape around this wrench. Needle nose vice grips, mult allen wrench, combo screwdriver, also safety wire, tiewraps a spare clutch perch and lever and brake lever also a few common bolts and nuts. If a long ride I bring lighter, lite sticks, mini mag light ,toletpaper, ink pen and 18" tube.
  • StreetMoto
Posted October 05, 2002 - 10:56 AM
How are you guys changing and/or patching your tubes? My normal tire irons are are pretty big and its a major pain in the a** to get the tire off and on. what is the trick here? Are you just packing the big tire irons or is there some trick I dont know about?
  • Dan_Lorenze
Posted October 05, 2002 - 03:33 PM
Changing a tube on the trail isnt such a big deal but if you're in a race situation you're better off getting the Bridgestone "Extra Heavy-Duty" tubes and running "Slime" in them. I don't carry tire irons anymore with this combo. After thousands of miles I've yet to get a flat. They do weigh more that a thin tube but I think it's good insurance. my .02
  • hoppalong426
Posted October 05, 2002 - 05:14 PM
Carry a small can of seal n air, located at your local pep boys. And my trusty AAA card! When the going gets tuff! :)
  • fastmonstr
Posted October 05, 2002 - 07:24 PM
What do you mean by "modified"? Did you cut it??
  • Fryboy
Posted October 06, 2002 - 04:04 PM
YO !!!!!
You forgot the inflatable doll ! Can't leave home without my bit*h ! :D Slime can assist if she gets a flat.
Moose has yet to develop the heavy duty version. I hear its due in 2003. :)
  • scott_h
Posted October 06, 2002 - 06:13 PM
You can cut your 27mm wrench (box end) down to fit in your pack. Just use your boot for added leverage. You can do the same with a 22mm for the front axle as well. Better yet, weld these two pieces together and now you have a single tool that will do two jobs.
If you don't want to fool with all this, get a 22mm x 27mm “Rider Wrench” from Fredette Racing. It’s about 6 inches long and about 1/8" thick. You can get them through Fredette Racing, Baja Designs, MSR or other online dealers for around $17. A little pricey, but the size and weight are hard to beat.
  • fastmonstr
Posted October 08, 2002 - 10:47 AM
Scott H- that was exactly what I was looking for!! I just ordered the 22mm-27mm Riders Wrench for FRP.
  • scott_h
Posted October 08, 2002 - 06:42 PM
Glad to help. Say hello to sixth street for me and hook em horns!
Posted October 09, 2002 - 07:52 AM
How did you get this puppy to let you post as "Anonymous" when I don't sign in it tells me I can't start a thread....Interesting....
Bonzai :)
  • Florida_426
Posted October 11, 2002 - 04:26 PM
Check the initial date on the post. Did the boad allow anonymous , unregistered posts back then ? Just a thought.
Bill :)
  • Thumpy420
Posted October 12, 2002 - 04:21 PM
