4 speed/5 speed/or 6 speed, what do u prefer
25 replies to this topic
  • speddie3
Posted September 22, 2005 - 07:15 AM
So I didn't realize that the 05' yzf's had only 4 gears, and the new 06' yzf's are going back to 5, along with the 2-smokes having 6 gears in 06'. I noticed this when I was at the dealer yesterday looking around. Just wondering how people like the lack of the 5th gear on there bikes cause sometimes I almost want a 6th in mine.
So for the 4 gear people, do you ever "run out of gears" or dislike the gear ratios since they are farther spread?
Also I use to have a 125 smoker and it felt like i was always shifting and it was just a 5 speed. Now from what i read the 06' 250/125 smokers are gonna have 6, which to me is fine except that they are kinda close ratios so your gonna shift even more. Seems like gear selection going into a corner is gonna be all that much more important.
let me know what your thinking.
Posted September 22, 2005 - 07:57 AM
Two-strokes, especially little ones, have such a narrow power range that they have to have a 6 speed.
I run out of gears, sure, but that used to happen when I had a 5 speed, too. With gearing that makes the low gears the same overall ratio, there's a 3 mph theoretical difference in top speed between a YZ426 and a YZ450. All MX bikes are close like that.
What I'd like is the same first 4 gears and a one more on top, spaced the same as the others. With the wide torque curve the 450 has, they don't need to be any closer than that.
  • dmoney2023
Posted September 22, 2005 - 09:10 AM
i've never ridden a 4 gear bike, my 426 5 gear does awesome. So why mess with a good thing??? But on the track wider gears may be nice. But why would they be changing them back then?????
  • revolucien
Posted September 22, 2005 - 09:26 AM
Like gray said, the four I have with one more on top. I like the spread I have on the '04 450 but I would like one more up top.
  • mxis4me
Posted September 22, 2005 - 04:20 PM
on most mx tracks i like the 4 speed , i dont miss 5th at all. but when i ride the woods i miss the 1st and 5 th gears i had on my 00 and 02 426ers. hoefully ill get a 07 450 ,gonna get 1 more year outta the old 450.
  • ONLY4STROKES
Posted September 22, 2005 - 05:03 PM
The switch back to a five-speed is good for all.
That way the desert/woods guys can be happy with the MX guys.
Te four-speed only works well for motocross, IMO.
  • 450_rider
Posted September 22, 2005 - 07:18 PM
Down at the track i dont feel the need for a 5th gear 4th is plently but when iam out riding on trails you wish for that 5th gear so your rpms arent always so high but dont get me wrong my 03 yz450f easily does 140kph with its 4th gear
  • matt116
Posted September 22, 2005 - 07:33 PM
I'm looking forward to the extra gear.
I had to replace 3rd gear twice over two years, I atribute this to the 4 speed gear spread causing me to ride 3rd more.
  • ride yzf all the way
Posted September 23, 2005 - 04:35 AM
i like my 05 with 4 gears cause in the track you dont have to shift as much that what my freind said he like sit b/c that his 2 stroke he has to shift all the time
  • speddie3
Posted September 23, 2005 - 06:50 AM
It seems like your all on the same page as me, thanks. I don't race, just ride and without the 5th on mine I would be lost. I wish I had a 6th on top of the current five though. Well regardless of howmany I have, i am gonna log off and go ride, so later.
Posted September 23, 2005 - 07:01 AM
As it is, and as I've already said, the ratio spread between the lowest and highest gears in the YZ450 and the YZ426 is almost identical. The 426 has 3 gears in between, and the 450, only two. The gear spacing in a YZ426 is far closer than necessary (IMO, the spacing on my 450 could even be wider). Inasmuch as mine will hit 90 in 4th, I don't think I need much more, except for cruising graded roads at 70 mph.
The desert guys who are using a YZ426 have no major speed advantage over the 450, because the 450 can pull enough extra RPM in high gear to make up for the slight difference in ratios. The only way to get better top speed in either bike without gearing low gear higher is to substitute a WR transmission. In a 450, that gives you a somewhat lower first, the same three ratios (virtually) for 2nd, 3rd, and 4th, plus a fat overdrive on top. For $700, it's the way to go for a desert bike.
What I hope to see is the exact same first 4 gears, or close to that, with 5th spaced above 4th like the gap between the current 3rd and 4th. Then there would be an advantage to it. If it's just going back to the same old too-close ratio 426 box, I'm not interested.
  • katoom525sx
Posted September 23, 2005 - 08:08 AM
If you want an automatic get a 525sx stick it in 3rd and leav it.
The thing about a 6 speed is really only for the cross country bikes because the 1 is really low for the tight stuff and the 6th is really tall for warp speed in the open areas
  • 00YZ426FMRCD
Posted September 23, 2005 - 08:21 AM
I think it all depends on the gearing & type of riding. My 426 is a 5 speed but in all honesty, I would prefer a 4 speed for both MX & Woods - if properly geared. I like the idea of shifting less. I can't see the need for a 6 speed stroker unless you are running desert or running on long straight-aways...
  • Butta
Posted September 23, 2005 - 01:50 PM
Once again (and this happens more and more often) I agree with Gray. I leave my bike in 3rd for the majority of the tracks I've ridden, very very seldom needing to shift. I even upped the gearing (dropping 3 teeth on the rear) because the FMF pipe added more bottom end and I could lug it out of corners more. True, I don't race, but I find myself going plenty fast for my tastes!!
  • twistofthewrist450
Posted September 25, 2005 - 07:10 AM
I prefer the four gears for riding in the open Fields where your not shifting all the time you're just torquing it through the rpm's. Woods isn't a problem unless it is really tight then you use the clutch a lot I try to use my other bike for that stuff. On a track this thing hauls it rips off of idle, but is a little short lived up top. The four gears have never become a problem. Honestly, I might be slow, but I've found no need for a fifth gear.
  • Husky_Forever
Posted September 25, 2005 - 07:44 AM
6th gear is good for Baja and long desert races. :applause: Aside from that, a 5 speed works fine. :banghead: Steny
  • Matt96xr6
Posted September 25, 2005 - 09:41 AM
[quote name='grayracer513']As it is, and as I've already said, the ratio spread between the lowest and highest gears in the YZ450 and the YZ426 is almost identical. The 426 has 3 gears in between, and the 450, only two. The gear spacing in a YZ426 is far closer than necessary (IMO, the spacing on my 450 could even be wider). Inasmuch as mine will hit 90 in 4th, I don't think I need much more, except for cruising graded roads at 70 mph.
[QUOTE]
HEre are the ratios on the 450 4sp:
1 - 27/14 (1.929)
2 - 25/16 (1.563)
3 - 23/18 (1.278)
4 - 21/20 (1.050)
The 426:
1 - 24/13 (1.846)
2 - 23/15 (1.533)
3 - 23/18 (1.278)
4 - 24/22 (1.091)
5 - 20/21 (0.952)
So basically looking at those ratios, you can sum it up as this. The 426 in first gear has a lower ratio, then is close in 4th gear, but then you have the 5th gear that is below a 1:1 ratio effectively making it an overdrive.
Basically just like stated. But on a MX track, you never use 5th unless you are at a place like Honey Lake. 5th makes the bike more versatile to a wider variety of riders (from SX, to MX to offroad)
  • SureBlue
Posted September 25, 2005 - 10:06 AM
Agreed, I really like the 4-speed and going back to closer ratio 5-speed is not what I'm looking for. Just came back from track and I'm fed up with mixing the gears with my pinger, not something an old guy should need to do :applause: At least I'm still quicker than my son :lol: , but who knows next summer :banghead: ...
  • Matt96xr6
Posted September 25, 2005 - 12:55 PM
The 6 sp is great on the 125s so you can keep in the pipe super easily. 6sp are great for desert bikes also.
But 4 is nice, makes it a lazy mans bike for sure. Still like 5sps over 4 though personally.
  • teamtoxic
Posted September 25, 2005 - 07:23 PM
Personally, after riding my YZ450 for a full season now (moto, trails, street) I've come up with the dream transmission...keep the current gear ratios as they are but bring back the super low first gear that Blue dropped when they went to the 4 speed and add a TALL sixth gear on top. On the street I miss that 1st gear my 426 had (during takeoff). When I'm trail riding or on the street, I'm always grabbing for another gear.
Now obviously this is completely unrealistic given the current direction of motorcycle development, where motor dimensions and weight must be minimized. However, a motorcycle carrying a transmission like this would be the most versatile machine manufactured. Motocross, trail riding, supermoto...everybody would be happy, especially me.
Cheers
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
