Gas Tanks
6 replies to this topic
  • Chris wood
Posted September 21, 2005 - 07:20 PM
DOES ANYONE OUT THERE KNOW IF THE GAS TANK FROM MY FRIENDS OLD XR600 WILL FIT ON TO MY 03-XR650L.NEED TO KNOW BEFORE HE SENDS IT MY WAY,WOULD REALLY APPRECIATE A QUICK RESPONSE,THANKS GUYS. :banghead:
  • Red4x4neck
Posted September 21, 2005 - 08:47 PM
I am not knowledgable enough to know the differences down through the years but I would imagine there are some so you may wanna supply the year of of the "old xr 600" ......just a thought
Rob
  • Red4x4neck
Oh and turn off the capps lock
  • FOUR STOKED
Posted September 21, 2005 - 10:49 PM
The mounting system is different on the 600. The 600 has two brackets that bolt too the down tube that hold the front of the tank up. The 650L has rubber donuts that slide on tabs on the backbone, and the tank on the 650L has C cups that slide around the donuts. The 600 is held on with a rubber strap at the back where the 650L has a bolt. That said, you can do it with fabrication, but it ain't worth it with all the aftermarket tanks available. :banghead:
  • roadcam
Posted September 22, 2005 - 02:40 AM
my advice is to go to the gas-tank websites and see if their Part##s match up .. the way my IMS tank mounted up does not utilize the 'donuts' mounting, so I would think the 600 tank may 'possibly' fit
  • FOUR STOKED
Posted September 22, 2005 - 08:21 AM
B]Originally posted by roadcam[/B]the way my IMS tank mounted up does not utilize the 'donuts' mounting, so I would think the 600 tank may 'possibly' fit
How is the IMS tank secured Roadcam? I have no experience with the IMS tanks, but I did mount a XR 600 tank on my L some years ago and had to utilize the brackets that were used to originally hold the wings on the front in unison with some aluminum stock attached to the bracket holes under the tank. It was a pain in the arse. :banghead:
  • Dual_Dog
Posted September 22, 2005 - 05:16 PM
If the price is worth modifying the machine and/or tank, then get the tank. Best plan is to get the tank that's made for that model. If it's a (used) Clarke 4.0, it'll fit with the available XRL install hardware without any modifications.
That said I've got the Clarke 4.0 and it does use the stock rubber bushings and the ear or "c" cups are molded into the tank. Fits well but lacks lateral stability. So I came up with a quick and simple bracket to solve this. I've got a photo of it in "my garage."
  • 9 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  29 replies
  • 4 replies
