BK Mod ?
13 replies to this topic
  • vorra65
Posted September 21, 2005 - 04:35 PM
Can anyone enlighten me, as to what the BK mod is exactly. I tried the search function without sucess?
Also, which year's does it apply to?
Thanks
  • crfdude86
Posted September 21, 2005 - 04:43 PM
ya i want to know what a BK mod is
  • jwriott
Posted September 21, 2005 - 06:22 PM
The BK mod stands for Brian Kinney I'm pretty sure. He was a Yamaha Mechanic. It basically modifies the squirt duration of the pumper carb. Stock, it squirts around 3-4 seconds. You want to limit that to less than 1/2 second.
http://motoman393.thumpertalk.com/
  • vorra65
Posted September 21, 2005 - 07:26 PM
Thanx for the link-vmax
After reading the write up, I'm assuming this mod is not applicable to my WR which is an '04?
Anyone?
I'm getting real close, just a hint of a stumble when I twist it swiftly. Installed the NCVQ (YZ) needle this evening, and it cleaned up alot. Need to get out and give it the SOTP test. :banghead:
  • GCannon
Posted September 22, 2005 - 01:23 PM
the BK mod rules! be very carfull in your set up also in your selection of fasteners. You will need to rejet after the mod since you just took away all that fuel. Done correctly you bike will respond much quicker and cleaner. Use VMAX's link Good luck using a stopwatch under a 1/2 second anything under 1/2 second should be good
  • ToooFaarOutt
Posted September 22, 2005 - 01:33 PM
BK mod ? Have it your way Hurry get the BK ( Burger King ) mod while supplies last. LOL
  • vorra65
Posted September 22, 2005 - 01:39 PM
So can this mod be used with the 04 WR?
  • Gadsen
Posted September 22, 2005 - 07:33 PM
I'm doing the DQ mod, then a follow up KFC mod also! :applause: :banghead:
  • vorra65
Posted September 22, 2005 - 07:56 PM
I'm doing the DQ mod, then a follow up KFC mod also! :lol: :applause:
Ok, since I'm a newbie round these part's-I guess this is my hazing. :banghead:
:lol:
  • SpeedBlitz
Posted September 23, 2005 - 05:29 AM
Scroll to the bottom of this page (http://www.thumperfaq.com/ap_mods.htm) for info on BK mod on 2003+ models. Initially, I thought that the BK mod didn't apply to 2003+ models, but according to this info, it does; however, I don't hear of many people doing it on 2003+ models. It seems that you can get AP duration/squirt as good as it needs to be with leak jet changes and AP timing adjustments (for more info on AP tuning: http://www.thumperfaq.com/ap.htm). Some also add an aftermarket AP cover.
  • vorra65
Posted September 23, 2005 - 07:39 AM
OK, perfect. The last link you provided explains it all-Thanks. I remember doing a diaphragm (spl) mod to my YFZ in the early tuning stages. After I got the quad dialed I guess I rode myself silly since I forgot about that. :lol: Since the WR sports the same carb, I'll get it perfect or else........ :banghead:
So maestro, :lol: maybe you can lead me to a thread regarding that nasty mess of hoses on my '04. If they are only part of the CA emission legal B/S-then they need to go. If you could, I'd appreciate it. Thanks again :applause:
  • jbrooks26
Posted September 23, 2005 - 11:33 AM
I think you want the AIS removal kit, it can be found here on TT. Hope this helps.
Josh
  • vorra65
Posted September 23, 2005 - 11:42 AM
Josh
My '04 doesn't have the AIS-hence the fawkin red sticker I have to tolerate.:banghead:
All the hoses, I'm refferring to-are what is reffered to here at TT as the "octopus" :lol: I believe.
I'm learning. Would be nice to get rid of all those clear hoses-what a PITA they are to deal with when working on jetting. :applause:
  • SpeedBlitz
Posted September 23, 2005 - 01:36 PM
I believe the term "octopus" generally refers to the AIS, not the carb hoses, but you are right, there are a lot of hoses on the FCR carbs. Don't remember reading about eliminating some of the houses, only routing them differently. Some route the top vent hoses to the airbox as a waterproofing measure, in addition to the breather vent.
I think you can consolidate some of the hoses using some plastic Y-shaped tubing connectors, but I haven't read a thread about this yet.
Waterproofing Thread:
http://www.thumperta...t=waterproofing
Link to waterproofing, includes shots of re-routed carb vent hoses to the airbox:http://www.unruhly.n...info/index.html
