Dry clutch plates
3 replies to this topic
  • Steve928
Posted September 18, 2005 - 09:04 PM
I've got an '02 650r. The motor is stock, except for the uncorking, with a pro circuit full system. I removed the judder spring and added the full size fiber disc in the clutch, with the heavy duty honda springs, and neither myself or my racing partner abuse the clutch. The clutch doesn't slip under a load however, when I stop then begin to go again it grabs very harsh and makes a terrible noise. When I took the clutch apart, all of the plates are dry, and yes they were soaked prior to install. I have gone through everything I can think of on the bike. Can anyone help?
  • knuklehead
Posted September 19, 2005 - 06:38 AM
I think you should put judder back in,and one extra steel, take out extra fiber. that how i have mine set up.
  • TimBrp
Posted September 19, 2005 - 08:53 AM
Mine did the same thing. Make sure your basket isn't grooved. Sounds like the fibers are getting hung up.
  • Steve928
Posted September 26, 2005 - 11:01 PM
Thanks Tim I will give 'er a try.
