Split in fuel tank
3 replies to this topic
  • gmiles
Posted September 18, 2005 - 11:39 AM
I have found a small split in my fuel tank. Its underneath the tank at the end where the rubber band holds the tank still.
Do you gents have any idea what I can do to seal it?????
  • matt116
Posted September 18, 2005 - 12:20 PM
I had my tank spit to.
I used a plastic welder kinda looks like a soldier gun but blows out a concentrated stream of hot air about 3/16 dia.
You may have to bevel out the crack to get penatration and use some filler, I took a razor blade and cut some slivers off the bottom of the tank to use as a filler. You must use a filler that is chemically the same or the "weld" won't stick.
o-ya make sure you clean the area really good iso alcohol works good.
  • ONLY4STROKES
Posted September 18, 2005 - 12:24 PM
Plastic welder does the trick, but if your in a pinch...use soap.
I would just buy a new gas tank, though. Try one from Clarke.
http://www.clarkemfg.com
  • bg10459
Posted September 18, 2005 - 05:18 PM
someone posted on this recently. I think it may have been replaced by the dealer for free :banghead: . Do a search.
  • Hot  38 replies
  • 5 replies
  • Hot  47 replies
  • On January 15, 2017
