powercore insert
2 replies to this topic
  • Anthony CRF450
Posted September 16, 2005 - 03:51 PM
hi guys
i have an 05 wr450 with a powerbomb header and powercore 4 silence and considering installing a fmf quiet core insert. (way too loud)
has anyone done this?
is it a lot quieter or just a gimik?
did it affect power delivery?
did jets need to be adjusted? what do you tweak i.e needle or just fuel screw?
any other coments on this insert appreciated?
Thanks heaps :banghead:
  • Cedric
Posted September 16, 2005 - 08:34 PM
Try searching for this, I think Indy swears by this setup. If I recall correctly, he found this to be the best compromise b/w power and noise, even better than the FMF Q. I want to get one for my (too loud) PC 4, but I've been dragging my @ss on the issue.
  • ncmountainman
Posted September 17, 2005 - 06:28 AM
i ran that setup on my wr (pb/pc4/qc insert) and it worked well,mine tested at 98db(103 without). yes it takes a tiny bit of bottom away but if noise is an issue its worth it. its a way better setup than the Q as far as power :banghead: it may require turning the fuel screw in a little (maybe 1/2 turn) because it will tend to richen it up.
