Headlight on a 2002 YZ426F ???
24 replies to this topic
  • REWCBA
Posted September 15, 2005 - 05:16 PM
I have a 2002 YZ426F and i Ordered a ACERBIS CYLOPESS HEADLIGHT
and i have been told that i can hook it up with out buying other stuff
Can anyone help me figure this out
  • 02YZ426
Posted September 15, 2005 - 05:51 PM
Ummm... Your going to need a lighting coil, or battery to run that. And if you already have a lighting coil then you will need a voltage regulator.
  • ONLY4STROKES
Posted September 15, 2005 - 06:04 PM
No battery needed, but he'll have to get a stator along with some other things.
  • 02YZ426
Posted September 15, 2005 - 06:08 PM
Ya.. no battery needed if you have a good lighting coil, some guys go the cheap route and run only a battery and dont bother with the coil. I reccommend the Baja Designs 180watt external coil... expensive but puts out tons of power for some serious light!
  • ONLY4STROKES
Posted September 15, 2005 - 06:12 PM
I dont think anybody with a YZF is running a battery for lights...there isn't a place to put it.
  • 02YZ426
Posted September 15, 2005 - 06:15 PM
Yes there is.. in the airbox! Now its going to be a small one of course. I am currently using the Electrex USA 45watt coil in my 426 and I have to run a small battery with it so my turn signals will work at idle and so my headlight wont dimm out. Thats why Im getting the BD one this winter.
  • REWCBA
Posted September 15, 2005 - 06:30 PM
Thanks guys where can i get what i need if you have some links that would be great
  • 02YZ426
Posted September 15, 2005 - 06:38 PM
http://www.bajadesigns.com/
https://www.electrosport.com/
  • REWCBA
Posted September 15, 2005 - 06:55 PM
thanks man
this is the headlight i have ordered
CYCLOPS HEADLIGHT
The first approved headlight for all on and off-road bikes. It can be
used on non-fairing bikes to street fighters. Exclusive customized
design: nylon surround, polypropylene numberplate, polycarbonate
reflector, cast aluminum headlight body and tempered glass lens.
• DOT and SAE approved
• Adjustable angle
• Universal fitting with anti-vibration rubber strips
• Removable number plate; available in a wide variety of colors
• Protective, transparent polycarbonate lens cover supplied for off-road use
• Heat resistant plastic headlight support
• Spot light fitted with 55 W halogen bulb, Flood light fitted with 55 W halogen bulb and 5W incandescent bulb
  • REWCBA
Posted September 15, 2005 - 06:57 PM
Would this run that ? or not
ElectroSport ESL380 Lighting Stator
4-pole lighting stator with 50W lighting output. includes backing plate, pulser coil, pre-wired ready to install. Comes with our industry leading one year warranty.
  • 02YZ426
Posted September 15, 2005 - 07:05 PM
Yeah.. that will work but you will need to run low wattage headlight bulbs. Probably 20watt bulbs per side. The light will flicker at idle and you will need a battery if you plan on running turn signals. You can get away with no battery if you run LED taillight. The Baja Desighs is much better cause you can run 70watts per side easily. My coil only puts out 45 watts and thats bare minimum for a headlight.. but I dont ride my bike at night so it really doesnt matter to me... its really only there so it can be legally plated for street.
  • 93gt
Posted September 16, 2005 - 02:09 AM
I asked about this one too and it seems really weak. I went with a WR stator and flywheel. I think you still can on your bike but on the newer 450s Im not so sure it will fit. The Yamaha parts are alot cheaper than the external one, although that one looks very easy to install if youve got the scratch. Moose racing has a trailsport harness (actually Electrex makes it for them) that you can buy from Dennis Kirk. It has the handlebar switch for the lights, and a kill switch, and a voltage regulator. The battery in question is for those fortunate enough to be able to street plate their bike. Its required by most states that the taillight stay on for something like 20 minutes. I originally bought the Dakar dual sport kit for my 400, and it in fact has a battery built into the controller behind the headlight. Go to Electrex.com for instructions on modifying the WR stator for your YZ if this is the route you take. ( Its very simple) Im waiting for my UFO twin headlight as I write, along with a WR replacement rear fender with taillight. The Cyclops one looked cool, but a little too Star-Treckish for me. Put up a pic when you get it on there tough, Id like to see how it actually looks! The other advantage of the WR set up is the heavier flywheel which makes it less easy to stall.
  • REWCBA
Posted September 16, 2005 - 02:17 PM
Thanks for all the info
I ordered my cyclopes headlight from www.azmotorsports.com and they said they can get me a replacement Coil that allows you to hook up a headlight for $197 and they also told me to check about getting my stator rewound what do you think about that
  • REWCBA
Posted September 16, 2005 - 02:29 PM
I just got an email and the guy From AZMOTORSPORTS told me that it made for running a headlight and tail light so i will have enouph power to run it on
  • 02YZ426
Posted September 16, 2005 - 02:44 PM
Does this AZMOTORSPORTS know what they are talking about? They want to sell you a replacement charging coil and still want you to get your stator rewound? That doesnt make sence.. A stock coil is mounted to your stator plate behind your flywheel.. it has 4 posts on it, and all 4 are wound for IGNITION. When you buy an aftermarket coil to run your lights it will also have 4 posts, but 2 are wound for charging and the other 2 are for ignition. The new part is going to be a direct swap over.. so you wont have to re-wind anything. Also, any coil you can fit behind the tiny flywheel that a YZ426 has isnt going to push any more than 50 watts, I'll guarentee that. So like I mentioned before... you will likely end up with two 20watt bulbs for headlight, and run an LED taillight and you will be fine.. BUT your lighting wont be all that bright so dont rely on this unit if you are doing a ton of night riding... Trust me.. been there, done that.. and if you want a REAL headlight get the Baja Designs one.. its worth the money. If your happy with 50watt output, PM me and I will sell ya mine! Im getting the Baja one so I wont need mine.. Paid $220 USD for it and you can have it for $120 if you are interested.
  • REWCBA
Posted September 16, 2005 - 02:51 PM
Thanks but i can see putting close to $500 on my bike to run a headlight i just wish i could find it cheaper
  • yogist
Posted September 16, 2005 - 07:38 PM
Is this baja desighns kit for dual sporting a yz ??
I am looking for a wr to dual sport..Theres not many of them in the trader
but a bunch of nice yz 450s for around 3000.00...
Can I dual sport it for around 500.00...??
  • 02YZ426
Posted September 17, 2005 - 04:05 AM
Baja Designs has everything you need to get your bike completly dual sported... but $500 will only get you the charge coil, lights are extra. Its cheaper to just buy their coil and make the rest of the kit up yourself. Check out "my garage" and check out what I did with mine.
  • REWCBA
Posted September 17, 2005 - 07:08 AM
The shop around me told me that i could get a WR stator and Flywheel to put on my bike and it would work with my headlight with out any problems they were told this by ACERBIS
  • REWCBA
Posted September 17, 2005 - 07:12 AM
Hey 02YZ426
I see that you have the Trailtec computer I ordered one and it should be here soon along with my cyclopes headlight
How do you like it is it worth it ?
  • Hot  113 replies
  • 10 replies
  • Hot  30 replies
  • Hot  50 replies
