help XR650R streetable project. light, subframe
6 replies to this topic
  • Zapp22
Posted September 13, 2005 - 07:43 AM
all
have worked on my XR650R to get ready for tagging, but I'm not happy with way lights came out and want to redo.
if you know part numbers/brandnames/source for any help with this:
- need good LED tail/brakelight instead of the weenie bulb type I have now
- need a headlamp that can be rigidly mounted somehow. the flimsy one on there now is the typical rubber-band approach, very difficult to get the beam useful, and it isn't too bright, which brings up the stator question:
- what's the best swap-core stator? source? link? help??
- Planning on using DualStar mirrors. if you have an opinion, pls say
- turn signals: would like fork-mounted durable turn signals for front, and something very small/close-to-fender for rear. have no clue which way to go on this. Really admire the signals on the Suzuki DRZ-S model. Something of that caliber would be the bomb
I"m trying to fix this bike in such a way that it can be ridden ANYwhere, long stretches on pavement if the need arises, but ridden safely [driver notwithstanding!!]
thx
z
  • TimBrp
Posted September 13, 2005 - 08:27 AM
Check out the Baja Designs quick release kit. It has all you need and more.
  • ImpalaR1
Posted September 13, 2005 - 09:18 AM
This is what i got, the 12v from the stock coil is enough to power everything, just not very well at idle.
http://www.procycle.us/main/dskit.htm
They also have this if u want to spend the extra for 200 Watts!
http://www.procycle..../lightcoils.htm
  • ponq
Posted September 13, 2005 - 09:22 AM
That's a great deal. Too bad I'm already dualsported.
  • xr_stamm
Posted September 13, 2005 - 09:23 AM
I'm new to the forum, but let me help out. Go to www.superbrightleds.com. They have many options for LED's that don't draw many amps (miiliamps actually). I got a 1.25" square with 40+ led's that acts as my stop light and running light. It all fits under the stock XR650R tail lamp cover. It take some wiring re-do and a little bracket fabrication, but well within everyone's means.
David
  • BrettJ
Posted September 13, 2005 - 02:52 PM
If you want a good rear light setup go to BWB site his is sweet http://www.borynack....nder4xr650r.htm
  • Zapp22
Posted September 13, 2005 - 05:51 PM
i am looking at the boynack site [which i had previously bookmarked] but do not understand the page cited, at all. hate to admit such desperate ignorance but it makex no sense to me
z
