I have aquired a 194 XL600R
3 replies to this topic
  • Sawsall
Posted September 11, 2005 - 06:55 PM
it needed a pulse generator to get it running...
Anyway, now that I know it runs, what are some cheap upgrades?
I plan on ditching the stock airbox for a K&N pod and a universal slip on Supertrapp...
is the stock dual carb system good?
  • goblin127
Posted September 12, 2005 - 04:05 AM
stick with the stock airbox and put a uni or a k&n inside it.Better to prtect the air filter than to let it hang out there in the open. The dual carb system is ok as long as there in sync. and its running fine leave it alone. Is the bike in good shape and in stock form?
  • targetdrone
Posted September 12, 2005 - 06:38 PM
Yes, keep the stock airbox and get a Uni foam filter. Since it is a single cylinder bike, you don't have to sync the carbs. One opens before the other, actually. There is a link between the 2 carbs that can be bent to modify the timing of the 2nd carb opening. Do a search in this forum and you will even find which jetting to use.
  • Sawsall
Posted September 13, 2005 - 05:22 AM
Thanks guys...
The bike is fair... no back fender... I have an old pick-up tool box laying here, so I cut some diamond plate out & bent a fender...
The front-end needed rebuilt, but I happened to have a inverted one from a 02 RM125 that was modified by RG-3 so it is now on it...
Currently has steet tires/wheels for motard
I'm not going to run a front fender
  • Hot  186 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
  • 22 replies
