Silly Question
6 replies to this topic
  • Scoobie
Posted September 11, 2005 - 08:58 AM
Hi,
Went to do the valve clearances today on my 650R but the crankcase cover refuses to budge. The guy that had the bike before me just used the inspection cover and turned the back wheel, but I'd rather get the cover off and do it that way.
Are there any tips/hints to getting the cover off - I've tried using a mallet tapping around the cover but no joy.
Cheers,
Scoobie
  • jim1234
Posted September 11, 2005 - 10:58 AM
It shouldn't be that tough . Are you sure you have all the bolts out?
  • Scoobie
Posted September 11, 2005 - 12:38 PM
Yep, all out.
  • Thumpmeister
Posted September 11, 2005 - 01:43 PM
Yeah, there should be 4 bolts holding the inspection cover on. But, the thing that can make getting the cover off is the generator/alternator set-up. Since the system is magnetic, it sucks the cover on pretty tight, and holds it there. I've just used a rubber mallet in the past, and you have to hold the shift lever down to get it off all the way. The only thing you can really do is just keep tapping the cover, but try to pull it off as you tap. It may be hard, but thats just the way it goes on these.
  • wr450fyamaha
Posted September 11, 2005 - 04:47 PM
hammer? :lol: :lol: :lol: :banghead: :applause: :lol:
  • oldturtle
Posted September 12, 2005 - 01:45 PM
Hi,
For all XRs I put the tranny in high gear and rotate rear tire without removing spark plug. This is much easier because the motor has less tendancy to flop past the TDC mark.
You can sit on floor and look into inspection port while turning the rear wheel. I realize you would prefer to remove flywheel cover but what is the big deal about doing it the easy way especially since you are having so much trouble with cover. You will need to check valve clearance often if you ride much so make it easy on yourself.
  • Scoobie
Posted September 13, 2005 - 01:08 PM
Cheers all,
Scoobie
  • Hot  60 replies
  • 9 replies
  • 22 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  29 replies
