98 wr400 odo eliminator
10 replies to this topic
  • Messiah
Posted September 11, 2005 - 06:40 AM
been looking around for a 98 wr400 odo eliminator. flatlandracing and barumspro don't seem to have them.
anyway searched this forum and pple suggested that the yz counterpart fits nicely. however the p/n for the hubs are different :banghead:
anyone have any idea if it works for the 98?
  • simon@vic
Posted September 11, 2005 - 08:56 AM
just remove the cable and cap the threaded part.........
  • bdmmotard
Posted September 11, 2005 - 09:33 AM
+1.
i'm running a trail tech, but i'm thinking about finding a mechanical speedo off a 17" tire street bike. i think they're cooler and more reliable.
  • Birdie426
Posted September 11, 2005 - 10:09 AM
I had read that the YZ spacer won't work (Don't remember where). Plus, the WR doesn't have a seal outside the speedo side bearing like the YZs do. I expect that's the major difference...
Are the 98 WR hubs same as the 01 WR's? I just ordered one from Barnum's for my 01 WR. I'll let you know how it works.
  • Messiah
Posted September 11, 2005 - 04:31 PM
5BF-25111-00-00 vs 5BF-25111-01-00. not sure what the numbers mean.
do keep me updated on how well it works anyway. thanks
  • katoom525sx
Posted September 16, 2005 - 12:05 AM
Copy that I think the trail tech is junk so I put a xt350 speedo on my wr250f
  • Birdie426
Posted September 17, 2005 - 11:06 AM
Barnum's is backordered on the speedo drive eliminator for my 426, and don't know when they will be available...so I ordered the YZ spacer and seal today. Should be here by mid week. I'll post the results.
  • so_cal_sean
Posted September 19, 2005 - 08:31 PM
what was wrong with the trail tech i was just looking in to buying one
  • Birdie426
Posted September 23, 2005 - 11:19 AM
I got the YZ spacer today, and it works just fine. You do have to run the YZ bearing seal, though, as the WR doesn't have one on that side of the hub.
  • Messiah
Posted September 23, 2005 - 07:01 PM
thanks!
  • SJMC_DON
Posted September 26, 2005 - 07:51 PM
This is right :banghead: the YZ spacer will work, yes the hubs are different but only where the WR has the "cup" where the odo head goes on with the little tabs that actually spin the odo head. If your odo head has not grenaded (like mine) you can just unscrew the cable and buy a small rubber cap at any hardware store to cover it with, like mentioned above. Otherwise make sure you buy a YZ spacer and a YZ seal kit (2 seals versus 1) and you are good to go :applause:
