WR450 2005 dipstick problem
8 replies to this topic
  • Vader3d
Posted September 10, 2005 - 10:27 AM
I have a serious problem with my 05 wr450 oil dip stick.. every time I open it to check the oil level the oil spurts out..
Even if I follow the manual to run motor for 3 minutes from cold it still does the same thing.. am I going something wrong...
  • Indy_WR450
Posted September 10, 2005 - 10:45 AM
:banghead: Turn the engine off and then check the oil!
  • Vader3d
Posted September 10, 2005 - 10:59 AM
I do turn the engine off.... the oil presure is just to much..
  • trailriderjoe
Posted September 10, 2005 - 11:16 AM
I have the same problem every once in a while. I can run the bike as long or as short as I want to. If I shut it off and check it to quickly (within a minute or so), it will run out of the hole. :banghead:
  • sabin
Posted September 10, 2005 - 11:36 AM
This happens when you have filled more oil than specified in the manual. Once I filled 100ml more and the same thing happend to me. When you drain the oil do you drain from the frame and engine also?
  • Gadsen
Posted September 10, 2005 - 11:38 AM
Overfilled the oil. What it calls for is from "dry", and you will never have it dry again, once filled. So always add less that it calls for. I find 1 qt plus maybe 2/10th of another, ie 1.2 qts.
  • Vader3d
Posted September 10, 2005 - 12:47 PM
Bike was service by Yamaha agent... was its first service so refered it to the profesionals...
  • Indy_WR450
Posted September 10, 2005 - 12:50 PM
Check your filter screen on the drain from the frame to make sure it is not partially clogged! :banghead:
  • jasilva
Posted September 10, 2005 - 08:59 PM
Also check the crankcase vent hose from the head to the airbox. You may be clogged there and creating pressure.
Joe
