Risers for a Scotts clamp....
9 replies to this topic
  • cholwerk
Posted September 09, 2005 - 07:13 PM
Anyone have a scotts clamp with risers on it? Does it hold up? What brand? I would really like to find one that moved the bars forward and up ~1 - 1.5 inches. I am 6'4" and find the BRP to be quite craped for such a big bike.
  • Supplicate
Posted September 09, 2005 - 07:16 PM
I'm 6' 7"
BRP SUB mount:
I can't say anything but good about it :banghead:
  • cholwerk
Posted September 09, 2005 - 07:21 PM
Will it work with the Scotts triple clamp?
  • Supplicate
Posted September 09, 2005 - 07:26 PM
dunno for sure, i just purchased the whole top triple clamp kit from BRP.
What does the top of your triple clamp look like? Does it just have two holes in it to bolt the bar mounts to? If so, and the measurements are the same it would work perfectly.
Let me know if you want some measurements off the tripleclamp/bar mounts.
  • cholwerk
Posted September 09, 2005 - 07:47 PM
Thanks, I appriciate the help, I'll measure mine tomorrow and try to find the stock measurements on the web, if I can't I will take you up of the offer.
  • perryg114
Posted September 10, 2005 - 01:11 PM
I am sure I could make an adapter for the bar risers I make. Seems like all I would need to do is make a plate that bolted to the bar risers or triple clamp. I have a scotts damper that I could use as a model. Finding the center of the steering stem relative to the handle bars is the main measurement that I would need to make an adapter plate. The center of the scotts damper where the little arm attaches needs to be over the center of the steering stem.
Perry
  • cholwerk
Posted September 10, 2005 - 06:38 PM
Perry, thanks for the response. It is not the mounting of the damper that I am concerned with, but the fitting of bar risers to the Scotts tripple clamp (I already have the "dogbone piece.) Any idea if you risers woul;d work with the Scotts clamp? I would like to spend my money with a southern boy. (I am from Mississippi.)
  • perryg114
Posted September 11, 2005 - 04:16 PM
Well if you move the clamp forward you are going to have to change the Scotts mount as well. If you went with a straight up riser then you could probably use the damper with a longer center pin in your existing pin holder. There is nothing special about the scotts dogbone. The important thing is that the pivot center on the scotts arm is at the center of the steering stem. What is the Scotts part number for the dogbone you have. If it is the same one that fits on my DRZ400 that will help things.
Perry
  • cholwerk
Posted September 12, 2005 - 08:04 PM
Perry, thanks for the reply. I did not think about the damper pin holder. I will get the part number in the morning.
Thanks.
  • Docmarkw
Posted September 13, 2005 - 04:57 PM
I'm 6' 7"
BRP SUB mount:
I haven't had a chance to call Scotts or BRP yet, but does anyone know if they make this set up for the rear mount scotts stabilizer?
