smokin like crazy
5 replies to this topic
  • pullatrain
Posted September 09, 2005 - 03:55 PM
Hey guys I'm in need of you're vast knowledge. I have an 84 xr500r (in my service manual it shows mainly the same engine as the 600) and the last time i went riding it started smoking. It has smoked on start up since i have owned the bike ( i figured it has worn valve seals) and while going downhill but it will block out the sun when i as soon as i touch the throttle. It hasn't lost any power but used a half quart of oil in the two hours that i was out. What gives? Is this a common problem with air cooled engines? I'm guessing that i have worn the rings out and it's time for a new piston and rings but i would like to know if there are other things to check first. I have checked to make sure that the vent is clear.
  • pullatrain
Posted September 10, 2005 - 06:40 PM
no one has any tips, suggestions or hints?
  • No1TubaPlayer
Posted September 10, 2005 - 07:21 PM
get a new piston/rings.
the old rings have worn out and let oil into the combustion chamber. this is why your xr smoked.. and why it used oil.
  • pullatrain
Posted September 23, 2005 - 04:35 PM
since i have the engine apart are there some things that need to be replaced? I found that the cam has a worn lobe and bad rocker. The piston doesn't look like it was worn and the cylinder wall didn't have a ridge (I'm sure that doesn't mean much but might be help full info on my description). other than that everything looks to be in great shape. Do i need to replace all of the rockers or just the bad one, I plan on replacing them all but if there isn't any need it would save on the cost. Is there any place that is better than another to buy the parts bikebandit etc. thanks guys.
  • Xr650rhonda
Posted September 23, 2005 - 04:57 PM
http://servicehonda.com
  • pwrpapa
Posted September 23, 2005 - 05:26 PM
It's time for a complete rebuild. :banghead:
  • Hot  186 replies
  • 4 replies
  • Hot  60 replies
Washington
  • Hot  32 replies
  • 9 replies
