2 questions ,Oil? and Jetting
9 replies to this topic
  • GrinderCCM
Posted September 08, 2005 - 10:31 AM
Just bought a 2002 wr426 down in Vegas, when i was down there i road it a bit and it is awesome. after i road it for 5 min the first time i checked the oil and it was full.. it was kinda weird tho, the oil was a milky green??? should not oil be clear with a slight color???
The other question i have is, I live in Utah and the start or low elevation here is 4000 feet. I ride anywhere from 4k to 9k Feet. I’m taking the bike to get jetted for my elevation because i noticed a very little dip in performance, well basically when i pull the throttle fast it bogs abit. im guessing here but i think the air is thinner so the fuel air mixture is needing more air.
Should i get a Dyno or JD kit or something or just let them rejet it with the stock parts?
Thanks guys
  • GrinderCCM
Thanks guys
  • Joe Reitman
Posted September 08, 2005 - 04:27 PM
Milky green? Sounds like coolant in there...
  • CheYuen
Posted September 08, 2005 - 04:39 PM
That's what I thought too ? ? ?
  • walent215
Posted September 08, 2005 - 05:05 PM
def. sounds like coolant.prolly just need to replace the water pump seal-easy job and even though the jd jet kits and such are highly recommended on here i personally would just rejet with stock jets myself -youll save alot by doing it yourself
  • tcmII
Posted September 08, 2005 - 05:28 PM
jetting depends on how much effort you want to put into it. After reading many posts I went with the JD kit. Followed the directions and and extra email and al has been good. :banghead:
Just my thoughts.
  • Flaminchiten1967
Posted September 08, 2005 - 05:47 PM
I went with the JD kit because of its adjustability, I have everything I need to dial in the jetting now and am never going to look back.
  • RichBaker
Posted September 09, 2005 - 11:20 AM
Kendall MC oil is kind of greenish colored...
  • dman450f
Posted September 09, 2005 - 01:23 PM
change your oil and buy the jd kit,ride for a little while and check the oil color again,if its still milky , you got problems.... :banghead: :applause:
  • GrinderCCM
Posted September 09, 2005 - 02:34 PM
Great,, thanks. Ill try that..
