Powerbomb headpipe?
So I realized this weekend, just how flimsy the stock Ti headpipe is on my 450. Just a few little rocks flipped up by my front tire, and its dented all to crap. I am assuming that if I go to the stainless powerbomb, it should be a LOT stronger, yes? Also, does the powerbomb fit the stock exhaust? I like the stock can, and will probably end up getting a PMB insert for it.
Thanks
I've got the PB header and it is a thinker guage of steel than stock. It will take more abuse than the stocker, but I'd still reccomend a shield for it.
It's certainly MUCH better than the old Ti header its replacing. A drop of water would dent that thing.....
I had a Powerbomb on my '03 450 which worked fine with the stock exhaust. It is a bit stronger than stock, but it still didn't take too much to put a thumb print sized dent in it. Definitely recommend a guard for it.
