650 L Won't Shift!!!!
3 replies to this topic
  • Wheels up
Posted September 06, 2005 - 12:52 PM
My 650 L will not shift up or down gears. The shifter moves it's full range of motion. I can take off in 1st and it may take 7-8 times to get it to shift into second. Same for every gear. Seems to downshift a LITTLE better.
Shift fork?
  • XR650L_Dave
Posted September 06, 2005 - 01:01 PM
Sounds like the mechanism that goes from the shift shaft to the shift drum is out of whack.
Has it taken a hit (up, down, in) on the shift shaft?
Or (and here are the more hopeful things to check)
-is the shifter hitting the side case of the engine?
-is the shifter loose on the shift shaft?
-did you just change to MX boots?
Dave
  • Wheels up
Posted September 06, 2005 - 01:12 PM
Dave
No new boots. No hitting case. Not loose.
  • wr450fyamaha
Posted September 06, 2005 - 05:32 PM
ummmmm sounds to me like something in the case is majorly messed up.....my neighbor's ktm 65 had the same problem.....he still hasnt fixed it completely.....its been about 2 months and 20 hours of work on it but i dont know if its the same thing :D :D :D
  • 22 replies
  • 4 replies
  • 3 replies
  • Hot  29 replies
  • Hot  186 replies
