dual brake kit for WR426?
7 replies to this topic
  • mxyves
Posted September 05, 2005 - 06:54 AM
Does anybody know weather there's a Rekluse dual brake kit available for a WR426? And if not, did anybody managed to build one onto this bike with another brakecylinder or whatever?
  • Indy_WR450
Posted September 05, 2005 - 08:21 AM
I have seen one rider take the clutch cable and route it behind the rear brake master cylinder. He proceeded to weld a tab on the rear brake that extended rearward past the pivot mounting bolt. Then using the stock clutch lever he can apply the rear brake. The cable pulls up on the tab and activates the rear brake. The tab had about 3" of leverage to the pivot bolt and the 3/4" inch of cable travel seemed to work well. No overide clutch perch set up was the only bad issue with the set up. Dual levers would be a good way to go as per the new offerings by Rekluse. :D
  • mxyves
Posted September 05, 2005 - 02:29 PM
That's a good idea, to use the clutch cable for "steering" the rear brake, but...is it strong enough to remote the rear-brake with a cable and why doesn't a 450 brake-kit fit to a 426 anyway?
  • gobigblue
Posted September 05, 2005 - 03:45 PM
that sounds like an awesome idea!!!
  • Matty05
Posted September 06, 2005 - 01:02 AM
It is for supermoto
  • simon@vic
Posted September 06, 2005 - 08:02 AM
why not go hydraulic? there are set ups that come with a hydro line that threads into where the rear banjo bolt goes on the master cylinder.
but personally i would never give up my manual clutch. ever.
  • mxyves
Posted September 06, 2005 - 01:17 PM
any idea where to get this set?
  • simon@vic
Posted September 06, 2005 - 02:34 PM
