Counter Sprocket Seal Leaking
9 replies to this topic
  • ripntear
Posted September 05, 2005 - 05:43 AM
I guess that's what it is. I have noticed over the last few rides that there is an accumulation of oil and dirt on the frame just under the front sprocket. It's not coming from the vent tube.
Dose anyone know the part #'s for the seal and o-ring needed for replacement?
It's a 2001 426
Thanks!
  • ripntear
Posted September 05, 2005 - 07:36 AM
Found them:
Oil seal # 93102-32480-00
O-ring #93210-22298-00
I was having trouble finding a fiche.
www.worldofcycles.com
Posted September 05, 2005 - 08:49 AM
Here's the Real Fiche
http://www.yamaha-mo...parts/home.aspx
(no need to sign up, just go to the parts catalog)
  • ripntear
Posted September 05, 2005 - 08:51 AM
Thanks gray.
  • SureBlue
Posted September 05, 2005 - 01:35 PM
I have seen a wrong placed gas vent tube melt behind the sprocket due to friction heat build up, damaging the seal and causing all oil leak out during a race. (hope you understood my excellent english :D )
  • ripntear
Posted September 05, 2005 - 02:56 PM
Thats a weird one.
I'm not sure why mine starting leaking, but for around $11.00 I'll be able to fix 'er up.
I can understand all kinds of english. I is one.
  • SureBlue
Posted September 05, 2005 - 08:07 PM
Thats a weird one.
Yes, tell me about it! There were actually tube pieces between the seal and shaft and luckily it did not seize. My friend was leading the 1 hour race with the YFZ450 when he pulled over due to oil loss.
  • saucebox
Posted September 11, 2005 - 12:53 PM
my countershaft seal was leaking about 2 months after i took the bike off the showroom floor.. tried the fork seal trick on the countershaft and it fixed it right up.
  • Way Fast Whitey
Posted September 11, 2005 - 01:25 PM
make sure it not just excess chain lube flinging off your chain. it makes a mess on my bike and i hardly use any chain lube / use expensive stuff thats not supposed to fling.
  • mkporn
Posted September 12, 2005 - 09:54 AM
Thats a weird one.
Got a peice of string wrapped up in mine last year and it cut up the seal. I went to the local bearing and seal house and got a new seal and o-ring (there is a o-ring under the collar on the shaft) for $3.28 with tax.... The seal was 1mm wider but works great and was cheaper than factory. :banghead:
  • Hot  30 replies
  • Hot  36 replies
  • 0 replies
  • 10 replies
