valve springs
8 replies to this topic
  • Brettv
Posted September 04, 2005 - 04:55 AM
G'day everyone, how hard is it to replace your valve springs? ive got a kibblewhite spring kit and want to put it in myself, do i 'really' need a spring compressor?
also if my stock valves are ok, is there any reason to put kibblewhite ones in? or just keep the stockers?
cheers - Brett
  • Indy_WR450
Posted September 04, 2005 - 05:51 AM
As old as your bike is you might as well replace the guides, valves and have new valve seats cut. You cant see the fatigue or stretching on a ti valve but when it breaks the damage is going to be costly. :D
  • kirkw
Posted September 07, 2005 - 08:42 AM
Indy, bowing to your imminent knowledge, isn't the 99 Wr Stainless and not titanium? I have heard the steel has much more longevity to it than the titanium nd does not require a complete redo as quickly. Am I off base?
  • Cedric
Posted September 07, 2005 - 10:23 AM
I managed to get mine out by rigging up a sort of compressor with a large C-clamp and a piece of carefully cut out pipe - so that I could grab the keepers. It worked, but it was a major pain in the @ss for me. I would look into buying one for cheap at an auto parts store - I think the clamp cost me almost as much.
and yes, the valves are steel, so I would buy new OEM valves instead of the KW valves - seems like some people are having lots of trouble with them.
  • Brettv
Posted September 07, 2005 - 03:59 PM
hmm, thanks for the input guys, the kibblewhite valves are SS, they offer white diamond for my bike, and i asked them how much for custom black diamond for my bike and they wanted about $50 a piece!, ill pull it all off, do a leak test, and if they look ok and dont leak or seem to seal ok, i may leave it, i guess its better to do it all at once though.
-Brett
  • 99wr400
Posted September 07, 2005 - 08:07 PM
The stock springs work fine for me.
  • Brettv
Posted September 07, 2005 - 08:59 PM
yeah, but i got a set of kibblewhite racing springs (kit) real cheap off ebay $75 US
so whether to go kibblewhite black or white diamond would be the next question is what i ment
  • Hamish
Posted September 09, 2005 - 02:19 AM
When I changed the valves in my 426 (stock yammy) I also replaced the valve springs (with stock units) for no other reason that they were so cheap!
Some genuine parts are actually good value for money :banghead:
  • Brettv
Posted September 09, 2005 - 03:19 AM
hey Hamish, hows it goin? hows ur bike? goin again? is it back to stock?
when you changed your valves, how did you know they needed to be changed? did u measure them for tolerances? or could u somehow just tell?
