Aftermarket clutches used with a Rekluse
9 replies to this topic
  • LJ
Posted August 29, 2005 - 07:46 AM
Has anybody tried using an aftermarket clutch with a Rekluse?
I just smoked my clutch last weekend and I want to get a Rekluse. Rockymountain has a complete Tusk clutch for $35 as opposed to an OEM clutch through Bikebandit for about $160.
I'm concerned that the Rekluse was designed around the stock clutch and might not work with the Tusk clutch.
Also, does anybody know where I might get a better deal on a yamaha OEM clutch if the Tusk clutch doesn't work with the Rekluse?
Thanks!
LJ
  • 642MX
Posted August 29, 2005 - 10:23 AM
I think the Tusk clutch will work fine. Once the Rekluse is set up perfectly, it is actually easier on the fiber plates then a manual clutch. BTW I have White Brother's plates in mine and my fiancee's 250F has a Rekluse with Ferodo plates in it, they both work fine.
  • LJ
Posted August 29, 2005 - 12:38 PM
Thanks for the reply!
I was thinking that as long as the install gap is set correctly, it should work. However, I've never installed a Rekluse clutch so I'll guess I'll find out. For $35 for the Tusk clutch, it's worth it to see if it works.
  • Fastest1
Posted August 29, 2005 - 07:26 PM
You are right, if the installed gap is correct or in range, it should work great. The 35.00 is probably just the fibers, no steels.
  • ONLY4STROKES
Posted August 29, 2005 - 07:57 PM
Yamaha OEM clutch? Try http://shop.thumpertalk.com, way better prices than your local dealer.
  • LJ
Posted August 30, 2005 - 07:41 AM
It's the complete clutch. For $5 more you get EBC springs.
http://www.rockymoun...ar=1999&status=
  • ncmountainman
Posted August 30, 2005 - 01:26 PM
you don't need the springs with the rekluse :D al from rekluse told me that its tough to beat the OEM yamaha stuff.
  • LJ
Posted November 28, 2005 - 12:33 PM
Update:
No problem using the Tusk clutch with the Rekluse. The clutch worked flawlessly with the Tusk clutch.
  • schuon
Posted November 28, 2005 - 02:21 PM
I have a tusk clutch in my yamaha warrior and its holding up lots better than stock clutch, i have a ebc in my other quad and tusk has lasted and preformed just as well as the EBC.
  • beasleys
Posted November 28, 2005 - 06:13 PM
I am running a rekluse with the tusk plates on a 01 426 and it is working o.k. I am having some slipping but I think that is from the oil I was using. I ride with a couple of others with rekluse/tusk combos and they are having no problems. for 35 dollars I can go through 3 tusk sets before I even approach the cost of an oem set. :applause:
  • 0 replies
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
