wont shift into neutral
4 replies to this topic
  • dave2nh
Posted August 24, 2005 - 06:26 PM
I recently changed the water pump in my yz400f ..... 99 i got it all back toghether and it wont shift into neutral? anyone have any thoughts or ever had any problems like this? I am stumped!! I need help i am freekin out! thanks to anyone and everyone for help!!
  • dave2nh
Posted August 25, 2005 - 01:52 PM
please help !!! i have no clue what to do!
  • Pincushion
Posted August 25, 2005 - 03:19 PM
Did the water pump completely take a dump? Did you ride the bike for prolonged periods with a bum waterpump? Even if you did it should not have an effect on anything in the lower end, but you never know how much heat can be produced by these bikes.
Check you oil, rock the bike back and forth with the clutch disengaged and see if it'll go in. How did it shift prior to the water pump replacement?
  • bg10459
Posted August 25, 2005 - 05:19 PM
I assume the bike has not run since the new water pump. Definitely try rocking the bike with the clutch out and then kick it down (or up) with the clutch in. If it is running, you've got other issues.
Posted August 25, 2005 - 08:21 PM
How so? Will it go straight to second, or not shift at all?
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 5 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  79 replies
