Changing a YZ400F to a YZ426F
8 replies to this topic
  • Fast_Yamaha
Posted August 24, 2005 - 07:06 AM
I own a 1998 YZ 400F and have rode my friends YZ 426F and like it a lot more than my 400. I was asking around to see if I could change the piston and bore to accept the 426 piston. Will the 400 rod fit the 426 piston, or do I have to split the case and change the rod? Thanks for your help. :D
  • nimiz1
Posted August 24, 2005 - 07:59 AM
try this
  • Vick115
Posted August 24, 2005 - 10:05 AM
I have an '02 YZ426 thats practically brand new Ill sell ya. As much as I love the bike, The WR450 just seems to always be the bike I ride.
  • Hick
Posted August 24, 2005 - 12:41 PM
Pretty sure you need to change the rod, but I have not personally done this swap so I can't be 100% certain. My understanding is that the small end is bigger on the 426.
  • Joel
Posted August 24, 2005 - 12:42 PM
The 426 has a bigger diameter wrist pin. The cylinder bolts right up.
  • cobra427
Posted August 24, 2005 - 01:32 PM
What's up! My buddy has a 2002 426 and I've rode his bike a few times and yes it makes great power. My friend's bike is pretty much stock. I have a yz 400 with a big bore kit that takes it up to 420ccs' . That bore is on par with the 426. My bike has been rejetted, has a high performance exhaust and a high performance airfilter and it rips. I have never rode my bike and then rode his and felt mine was a step behind. My bike is heavier than his but other than that, they seem pretty similar. I think for you a simple big bore kit and relatively inexpensive & very common mods will get you where you want to be. If your really trying to set your bike up to identical specs of the 426 more power to you. :D
  • nimiz1
Posted August 25, 2005 - 12:46 AM
go to
  • Slowmotion426
Posted August 25, 2005 - 02:00 AM
  • Pincushion
Posted August 25, 2005 - 03:26 PM
You can have the 426 rod installed into the 400 crank and then bolt a 426 jug/piston on.
A friend of mine did this on his WR400. Eric Gorr did the crank work.
  • 9 replies
  • 0 replies
  • Hot  79 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
