does 01'426 have heavier flywheel than yz??
4 replies to this topic
  • 4Stroke4Life
Posted August 23, 2005 - 02:46 PM
i just put an 01'WR426 motor in my 99' YZ400, and i was wondering if it is common to put a flywheel weight on the WR as so many do for the YZ's. and man from reading some posts, starting this thing is going to be quite a bear.(myYZ400 had 450 cam) :D :D :D
  • Rich_in_Orlando
Posted August 23, 2005 - 07:24 PM
Yes, the flywheel is heavier on a WR than on a YZ.
  • R_Little
Posted August 24, 2005 - 08:15 AM
The wr flywheel is bigger....I don't know if there is room under the cover for a weight. Let me know if you find out.
Thanks
  • 4Stroke4Life
Posted August 24, 2005 - 08:58 AM
well i have a weight on my flywheel from my YZ400, and the weight is on the inside. so i am sure it would fit. are you saying that it could use a little heavier flywheel. that really is what i am asking, does the WR426 need a flywheel weight. is this a common mod??????
  • sharpmarble
Posted August 24, 2005 - 11:50 AM
I wouldn't. The stock WR's flywheel is heavy enough.
