anyone running a 120/100x18
6 replies to this topic
  • waterdog3
Posted August 23, 2005 - 11:59 AM
I changed my rear tire the other day, Dunlop 739 desert AT, and man is the new tire a lot taller than the old stock dunlop. Anyone noticed that there steering charteristics changing a lot sense the rear end is higher now????
  • vmxr
Posted August 23, 2005 - 02:03 PM
Yep, a bit less stable especially in sand. But it turns nice.
  • black_n_blue_thumper
Posted August 23, 2005 - 07:44 PM
Does putting a taller rear tire on make the steering feel more stable or less stable. :D
  • Gadsen
Posted August 23, 2005 - 08:59 PM
Yes, the original was a 110/100-18, meaning 110 mm wide, sidewall is 100% of the width. When you replaced it with the 120/100, you not only got wider, but being as the second number is still 100, this means the sidewall is 100% of the width. If you wanted a wider tire, but not taller, you should of used the 120/90-18, just gotten wider, not taller. This will change your gearing. You will feel it, especially if you have been used to one thing already.
  • JTWR450
Posted August 24, 2005 - 11:05 AM
I run a 120/100 in a Kenda Carlsbad and love it. Granted I ride mountain single track and the taller and wider tire is working out well for me. I just bought another 120/100 in the same brand and make and will not be running the smaller tire again.
  • Joe Reitman
Posted August 24, 2005 - 01:43 PM
Less- rear raises, fork rake (angle) decreases, as does trail. Bike turns better but twitchier at speed.
  • dirtr1der
Posted August 24, 2005 - 06:04 PM
Put a 120/100X18 on mine this year. Pirelli MT18. Love it. I didnt notice any difference in the steering or tracking of the rear end, but I also tuned my suspension so the bike rode way better this year from the suspension alone. Its a harder tire, so it does slip a bit more in the sand, but I was expecting that.
