06 Yz450
13 replies to this topic
  • Beanb1
Posted August 23, 2005 - 05:19 AM
I have been expecting to see some discussion on the recent Dirt Bike article on the 06 450. No weight change even with the new frame. But the weight is has been dropped considerably lower in the frame. Motor has been redesigned to include an oil reservoir at the front of the motor (one of the reasons for little weight change). If Yamaha has done their homework, the bike should be a lot easier to ride. :D What do you think?
  • 89yz250
Posted August 23, 2005 - 05:23 AM
5 speed transmission now on the yz too. no more 4 speed
  • Thumper38
Posted August 23, 2005 - 06:52 AM
Does anyone know for a fact that the 06 will have the same gear ratios in 1st, 2nd, 3rd gears as the four speed? I read this somewhere and would love for this to be true, I love my four speed!
  • Jetsprint2
Posted August 23, 2005 - 07:07 AM
I love my 4 speed as well. Reed, Ferry and DV even run 3 speeds at some of the nationals! I am switching to a 47 tooth rear sprocket to use 2nd and 3rd gear more. :D
  • Joe_Jet
Posted August 23, 2005 - 08:50 AM
They also reported that the YZ450 would not get an aluminum frame or any other changes just before Yamaha released the 06. I bet it will be around 229 when the mags test and weigh it!
  • SureBlue
Posted August 23, 2005 - 11:55 AM
I learned today the 450 is available not earlier than December, and that the yellow SE-version is not available in Europe, only in U.S. :D :D If I'm wrong, somebody correct me hey european bros.
  • 89yz250
Posted August 23, 2005 - 03:31 PM
some cool pics!!!!!
http://www.yamaha-mo...15/0/image.aspx
http://www.yamaha-mo...11/0/image.aspx
http://www.yamaha-mo...09/0/specs.aspx
:D
  • Ga426owner
Posted August 23, 2005 - 05:51 PM
Yea waiting sux............... :D
  • Satch0922
Posted August 23, 2005 - 06:16 PM
here is my advice....don't sit around waiting...be riding the crap out of what ever bike you have now....that way when you get your 06 you will be in shape and used to going fast on a heavier feeling bike.
Then you will get on the 06, get it dialed in and haul butt! :D
  • ONLY4STROKES
Posted August 23, 2005 - 07:40 PM
Its already easy enough to ride, I just hope it handles better.
  • TimFurryBalls
Posted August 23, 2005 - 10:50 PM
I'm so sure! You MUST be mistaken, thinking about when Ferry's 426 had 4 gears instead of 5. . . POSSIBLY 3 gears for SX, but outdoors. . .
  • Slowmotion426
Posted August 24, 2005 - 01:07 AM
Anybody know what the AMA legal minimum weight limit is for the 450's?
  • 00YZ426FMRCD
Posted August 26, 2005 - 11:36 AM
I doubt it... The 05 YZF 450 weighed in at 220lbs...(Dry weight) I bet the new 06 will be around 219 or hopefully less....The 05 CRF 450 dry weight is 218.5.
Heck 229lbs is approaching the weight of my 00 426! I hope the 06 is much lighter than that! :D
  • rpyfz450
Posted August 26, 2005 - 11:47 AM
I thought it was really odd they did this. This design looses a significant amount of cooling capability and adds bulk to the engine.
  • 0 replies
  • Hot  33 replies
  • Hot  36 replies
  • 0 reviews
  • Hot  47 replies
