Got Tips For A New WR426 owner?
10 replies to this topic
  • 6fiddy
Posted August 22, 2005 - 02:53 PM
Just bought a 2002 WR426. I had a xr650r before and uncorked it, jetted, piped etc. What do I do to the WR? It already has a white bros exaust w/ jet kit. Does it need to be Un-corked as well? Any feedback and maintenance tips would be greatly appreciated!!! :D
  • Matty05
Posted August 22, 2005 - 04:10 PM
Change the oil every 500kms. 1000kms seems way to long when the oil is metallic after 500.
Your bike is probably already uncorked. You got a pipe, just look at the airbox.
  • banffboy
Posted August 22, 2005 - 06:25 PM
You could YZ time it. That subject has been beaten to death (pros and cons).
  • byggd
Posted August 23, 2005 - 06:15 AM
I have the same bike and I love it. :D I ride tight stuff so I added the Rekluse clutch to avoid stalling and the 03 yz450 ex cam to give it auto decompress with a little more zip down low. The stock pipe flows pretty well once your pull the pea shooter out of it.
  • bigdrtrdr
Posted August 23, 2005 - 07:41 AM
My best advice for that bike is to learn the starting procedure. Then perfect it.
Great bike!
Eric
  • 6fiddy
Posted August 23, 2005 - 12:51 PM
Oh Yeah, I just found that out. If it stalls after its warmed up ,its impossible for me to start!!! I use the decompression lever and slowly kick it untill im at top dead center and i pull out the lil hot start switch and kick it! over, and over. NO START!! Im gettin a freakin heat stroke tyring to start this damn bike! Help me dude! What am i doing wrong here?
  • 6fiddy
Posted August 23, 2005 - 12:54 PM
Would you tell me ALL i need to know about an easier way to start this FReakK of a bike! I start her up 1st try each time when she is cold, no problem... but when she's hot....I want to dump her off a cliff i get so frustrated. :D My ankle is sore and ive lost 1/2 of my energy.. Help please!
  • bigdrtrdr
Posted August 23, 2005 - 01:28 PM
After its warmed up and you stall or kill it, pull in the decomp lever and give it about 3-5 kicks to clean out the motor. Then take it to TDC, Then go just past TDC with the decomp lever in. And giver a full kick. it should light.
If not it may need a new plug.
I dont even have to get my ass off the seat to start mine.
Good luck
Eric
  • goodluckmonkey
Posted August 23, 2005 - 02:07 PM
I've had my 02 426 for a few weeks now, and it's been a peach to start. Maybe it's because of the 450 exh. cam, or simply the way it's been setup.
Spec is:
'02 WR426F
Skimmed and flowed head
Full Acropovic exhaust
WR450F exhaust cam
YZ timed
From cold: Choke out, goes 1st kick
Warm: No choke, goes 1st kick
When i banged it into the floor riding MX: Hot start out, no choke: 1st kick, push hot start straight in.
The bike is the first for stroke i've owned with a kicker only, and it's so easy to live with. I just boot it once, and she fires straight up all the time.
I can only imagine there's a jetting problem if it doesn't run straight off the bat every time.
  • Dual_Dog
Posted August 23, 2005 - 02:11 PM
First of all, take it easy. It should light off easily when warm. You really don't need the hot start unless you've laid it down. I've never used that red knob even after dropping it.
Since you can start it (easily) when it's cold, does it idle normally when warmed up? Reason being is the idle setting can affect the hot starting if the idle is set too low.
When my '02 is warm it only takes one smooth kick to fire it up. It's very much like your old XR650R. Just do not give it any throttle at all. Once you're at TDC, pull in the decomp lever and push the kickstarter down about 1"-2" past TDC, release the lever and the kickstarter, then give it a smooth steady kick.
If somehow you end up flooding a warm engine, do the 10-12 kick clean out drill and then use the same technique as above. Good luck. You'll get it down.
  • dustdogg
Posted August 23, 2005 - 08:02 PM
Make sure to put a YZ throttle stop in if it hasn't been done. This will make the biggest difference.
