Coolant leak
9 replies to this topic
  • Barbados-WR
Posted August 22, 2005 - 02:45 PM
Sometimes coolant is leaking through small hole below water pump housing located on crankcase cover (right). Anyone know why ?
1998 YZ 400F
  • walent215
Posted August 22, 2005 - 03:31 PM
must be the water pump seal or shaft or both.all easy fixes
  • ONLY4STROKES
Posted August 22, 2005 - 04:25 PM
Yes, you have a blown water pump seal.
  • PurpleHaze896
Posted November 27, 2005 - 02:47 PM
i'm having the same problem as well. I know that i need the oil and water seal and the impeller shaft. I see the shaft and oil seal on this diagram but i dont see which one the water seal would be.
1: SHAFT, IMPELLER
((5JG5)) 298498-001 $23.93
2: IMPELLER, WATER PU
(5NX1) 295711-001 $48.47
3: WASHER,PLATE
(5NX1) 346834-001 $2.34
4: OIL SEAL
(5NX1) 358878-001 $3.00
5: OIL SEAL,SD-TYPE
(SD 12-22-5 HS) 4983-001 $4.47
6: BEARING
(B6001) 1121-001 $11.37
7: COVER, HOUSING
((5JG5)) 295069-001 $44.05
8: O-RING
((5JG1)) 295070-001 $5.88
9: PIN,DOWEL
(USA) 799-001 $0.73
10: GASKET
(5NX1) 796-001 $1.74
11: DISCONTINUED
(6X25) 363933-001
$0.93
12: PIPE, WATER
((5JG5)) 295076-001 $2.94
13: O-RING
(UR YAMAHA) 359108-001 $1.06
  • Barbados-WR
Posted November 27, 2005 - 04:29 PM
#4 is your "water seal" ,#5 is your "oil seal" . Buy those 2 seals along with shaft and bearing #6 . Problems Gone !!!! :applause:
  • PurpleHaze896
Posted November 27, 2005 - 08:25 PM
alright, thanks a lot
  • stvmoto
Posted December 08, 2005 - 08:51 PM
My bike leaks out of the same hole on the water pump.For me I noticed it just recently started leaking.The only difference is it only dribbles out a little bit of water then when the bike gets warm it stops???.......Any ideas anyone???
  • yamaboy23
Posted December 09, 2005 - 08:50 AM
change the seal
  • MotoGoalie
Posted December 09, 2005 - 01:26 PM
1998 YZ 400F
Hey, I was just in Barbados. Where do you ride. I did the Queens Route tour with a bunch of old fogeys. :applause:
  • slopoke
Posted December 11, 2005 - 05:39 PM
ya...same problem...sorry to dredge up this old thread, but i searched first!!...lol....so how do you know which you've blown?? why do these blow in the first place?? i just put the whole bike back together after my motard build and i was riding up and down the block...it started to dribble water out of the little hole....you don't always need a shaft do you?
  • Hot  50 replies
  • Hot  47 replies
  • Hot  28 replies
  • On January 15, 2017
