Chain
6 replies to this topic
  • wr450fyamaha
Posted August 22, 2005 - 06:07 AM
Ok, i ordered a chain and sprokets form the local honda shop........the sprokets are fine, no problems to report. but the chain is a parts unlimited LM 520 PRO5 O-RING CHAIN that is only rated for a 400 cc engine. my xr650l has a ton op power ups such as yoshi exhaust and a hot cam......possably a bigboar and high compression piston. do u guys think i will be ok with this one or do i need to get one rated for say a 750 cc engine. the tensile strength is somewhere around 7400 pounds. do u guys think i will be ok or do i need to go over there and teach them what chains fit what bikes!
  • wr450fyamaha
Posted August 22, 2005 - 06:09 AM
will it wear out faster than one rated for my bike?
  • TimBrp
Posted August 22, 2005 - 08:31 AM
Dude you are constantly looking for the cheap way out. Basically you're making a reliable machine, unreliable. Spend the money and get the right stuff. Obviously if you're asking you know the chain isn't right you just want re-assurance to the fact. Get a good quality X-ring (moose, DID, RK etc.) or staked chain and be all set. JT steel sprockets will be fine. Stay away from aluminum, it's for beer cans.
  • crmc33
Posted August 22, 2005 - 12:38 PM
you should be OK with a 520 chain even if its rated for a 400cc bike as most road going multi cylinder 400's will be making more power than your XR. Your XR may give the chainer a harder time in terms of transmission snatch and fatigue loading but you should still get a decent life out of it IMHO.
HTH
  • roadcam
Posted August 22, 2005 - 01:25 PM
a 7400# rated chain is fine with your bike setup ... my premium chain is only 8200# rated
  • Naru
Posted August 22, 2005 - 02:55 PM
After that chain wears out, it's worth it to spend the money and go with the DID ERV2. Costs a bundle, but your girlfriend will get strech marks long before the chain does.
  • frankstr
Posted August 22, 2005 - 07:39 PM
Get the right chain and quit worrying about it....... :D
Do it right the first time, Cheap out and it will bite you every time.......... :D
