16 or 17 tooth for yz450f
8 replies to this topic
  • dezertrider5
Posted August 20, 2005 - 08:31 PM
I was looking thru the internet and found out that thay sell 16 and 17 tooth front sprockets for the yz450.Has anyone ever tryed the 16 or 17 tooth sprockets,I mainly ride desert so I think this sprocket might help what do you guys think.
  • ksrrider
Posted August 20, 2005 - 09:02 PM
I also have a 450 set up for desert, and I only use a 15 counter with 48 rear. This set up is plenty fast, I did a GPS test and got it to 86 mph. How fast do you want to go anyway? Russ Pearson who leads national hare & hound runs that gearing, and on really fast stuff try a 15/45 combo. BTW...the case savers only work with a 15 front.
  • dezertrider5
Posted August 21, 2005 - 09:31 AM
I have a friend who uses 15/42 and says that he tested almost every sprocket combo(except the 16 or 17)availabe and said that 15/42 gives you the best top speed without loosing bottom or midrange power.
Posted August 21, 2005 - 10:40 AM
A 16 will require some notching of the chain slider. A 17 might require notching the swing arm. Either will need a custom case saver.
  • 02YZ426
Posted August 21, 2005 - 11:42 AM
If the 450 is anything like my 426, it will be difficult to get anything bigger than a 15 on it. When I installed a 15, I had to remove the case saver and it was still a tight fit. You might get one on but it will likely take some modification. I tried 15/42 and it does give you quite a bit more top end buy it will compermise the bottom end a bit.
Posted August 21, 2005 - 11:47 AM
I run a 15, and I also found the case saver had to come off to install it, although the same case saver does go back on and clears the chain.
  • dezertrider5
Posted August 21, 2005 - 11:49 AM
Im going with the 15 tooth
  • bdmmotard
Posted August 22, 2005 - 01:54 PM
i run 16/42. yep had to remove the case saver, and the chain knotched the swingarm guard. works great though, i happy with it for motard use.
  • bob333
Posted August 26, 2005 - 03:59 PM
try using wr they have wide ratio trannys
