wr450 jetting info wanted
5 replies to this topic
  • hairball123
Posted August 20, 2005 - 06:40 AM
hi there 03 wr450 just put full Akrapovic system on front pipe seams hot as f@#k and if you blip throttle hard from tick over it bogs and stops engine i live in uk so any advice on main jet and such would help ive looked through all the posts and read all the stuff but all i can work out is I'm too lean and need to swap main jet any simple help please
  • Dan_Lorenze
Posted August 20, 2005 - 11:31 AM
What elevation are you at?
  • hairball123
Posted August 20, 2005 - 12:20 PM
hi there not sure but live in the middle of uk leicestershire if this helps :D
  • dman450f
Posted August 20, 2005 - 07:35 PM
you are running way to lean man!!
  • Matty05
Posted August 20, 2005 - 08:48 PM
Way way lean.
I would go 48 pilot, richer on the needle.
Your main might be right but only you can tell.
  • hairball123
Posted August 23, 2005 - 01:02 AM
ive put 168 main in and 3 turns out on pilot for now seems ok but booked dyno for next week thanks
