Aussies
7 replies to this topic
  • FREDLINGTON
Posted August 19, 2005 - 11:19 PM
Need help i bought a wr 426 , i am 18 and need to know if i can rec reg it ie ride it in the bush without gettin in shit. are you able to rec reg a 426 at my age if not i'll have to let her go. :D
  • AUS_WR450
Posted August 20, 2005 - 04:05 AM
Dear Fellow Aussie,
You should be able to get the wr426 registered, provided you have all the ADR equipment fitted.
You'll need:
-headlight
-front and rear blinkers
-tail light
-rear brake light, that is operated by both front and rear brake levers
-horn
-speedo
-chainguards
-a muffler that isn't loud ( I think it needs to be less than 86db at 3500rpm)
-DOT approved tyres.
Best of luck
  • haydenjg
Posted August 20, 2005 - 04:15 AM
You can rec reg the 426 at any age with the necessary gear, but, depending on where your at you won't be able to legally ride it because of 250cc engine restricition on your licence, ie Victoria. If your not in Vic, all good!
  • bluebike1999
Posted August 20, 2005 - 05:52 AM
or tassie
  • nitro circus
Posted August 20, 2005 - 11:50 PM
try the forums at this aussie site mate http://www.dirtbikew....net.au/forums/
  • Blue Rocket
Posted August 21, 2005 - 12:13 AM
Here's a bit of info:
http://www.vicroads....26001F367E?open
  • FREDLINGTON
Posted August 21, 2005 - 05:25 AM
i cant afford to rack up fines so she probably have to go :D
  • Matty05
Posted August 21, 2005 - 03:49 PM
Dear Fellow Aussie,
You'll need:
-headlight
-tail light
-horn
-speedo
-chainguards
Best of luck
I've pulled most of that stuff off :D
It is a good thing that I don't have to worry about rec reg crap, noise crap,
police crap, etc.....
My bike is road registered though.
