Urgent: Need fork help
3 replies to this topic
  • mightymouse291
Posted August 19, 2005 - 01:43 PM
Hey i am putting my forks back together after replacing the seals. The outer shim does not seem to want to drive down in the fork tube. Do I drive it in with the seal or should it go in freely???
Nevermind I got it ...sorry for the tr=hread
  • Ga426owner
Posted August 19, 2005 - 02:01 PM
patience is key here....sounds like you took them completely apart. How did the old fluid look and how much sludge was at the bottom /comp valve?
  • mightymouse291
Posted August 19, 2005 - 02:35 PM
I broke them apart except for the damper system. I flushed it with new fluid them removed it. Once settled there was a good bit of metal and sludgey stuff..
  • Ga426owner
Posted August 19, 2005 - 02:58 PM
That is the stuff that settles at the bottom where the comp valve is..
