Carb position on 2001 YZ426
4 replies to this topic
  • TigcraftYamaha
Posted August 19, 2005 - 11:06 AM
Could anyone tell me whether the carburetor
on a 2001 YZ426 is supposed to be completely
veritical when keyed into the rubber manifold or
whether it is supposed to be a little off-vertical?
Thanks,
Steve
  • Yak
Posted August 19, 2005 - 11:38 AM
It has a slight lean to it. Both sides of the rubber coupling have notches that are supposed to line up with a tab in the head and the carb. If the tabs are resting in the middle of the notches, you cant go wrong.
  • TigcraftYamaha
Posted August 19, 2005 - 11:42 AM
Thanks. I appreciate it.
Steve
  • yamahadave
Posted August 19, 2005 - 06:32 PM
what will it cause if it it not lined up with the marks
  • TigcraftYamaha
Posted August 21, 2005 - 11:02 AM
I was asking about my carb being off-vertical because I've been trying to figure out what causes my engine to cut-out. I was thinking the carb might should be vertical and since mine isn't this could cause the fuel to lift the floats in the bowl too soon and shut off the fuel supply. I think I'm wrong. It looks like I have a transmission problem.
Steve
  • Hot  47 replies
  • 0 replies
