What size is the........
8 replies to this topic
  • c2
Posted December 26, 2000 - 03:47 AM
what size is the nut that holds the triple clamp assembly together? I'm installing the Scotts damper and I need to get that sucker off to do some grinding. Thanks.
Chris
  • Jeff_in_AZ
Posted December 26, 2000 - 08:15 AM
If memory serves correct, you'll need a 32mm socket for that nut.
  • Scott_F
Posted December 26, 2000 - 09:06 AM
I believe mine is 30mm.
  • TW
Posted December 26, 2000 - 09:15 AM
30mm is the correct size socket for my 99.
Just took mine apart and back together and it is still 30mm socket after looking for a second and third time.
99 WR400
BRC
NOHVA
AMA
[This message has been edited by TW (edited 12-26-2000).]
  • Guest_Guest_*
Posted December 26, 2000 - 09:28 AM
I was thinking 32.
Looks like we have at least narrowed it down.
Darin from Missouri 1999 WR400F
[This message has been edited by milkman2544 (edited 12-26-2000).]
  • Brian_in_Long_Beach
Posted December 26, 2000 - 09:45 AM
I'll check tonight - I bought a socket for that thing.
Brian
  • c2
Posted December 26, 2000 - 09:46 AM
BTW, I have a '00 if it makes any difference. Thanks.
Chris
  • So_Cal_Erik
Posted December 26, 2000 - 02:16 PM
Hey C2, Erik here, how's the damper working out? I hadn't heard from you and I hope all is well. Good luck on the install! Should be an easy one. Erik
So Cal Erik
Visit my club's site at <A HREF="http://www.ruts.org
" TARGET=_blank>www.ruts.org
</A>
  • c2
Posted December 26, 2000 - 04:18 PM
Hey Erik,
I have not been able to mess with the dampner yet. Between xmas, 9 week old daughter, work, freezing temps and snow, plus a few logisticals (need to borrow BIG metric socket which I'm not sure what size yet, drill stripped out bolts from the renthals to bend the crossbar, then grind the excess metal off the triple clamp....) well I havent't had alot of motorcycle time. But I'm slowly but surely getting there. Thanks for asking.
Chris
